426 to 450 carb swap?
6 replies to this topic
  • zaxcar1
Posted June 10, 2013 - 03:09 PM
I had once read that useing a 450 carb on the 426 helps with hard starts and makes them run better. But i cant remember what year 450 carb was the best to use and what might have to be done to get it set up? thanks
  • sid_125_04
Posted June 10, 2013 - 04:37 PM
I'm sure grayracer will reply but I asked this and an 08 is the best I put one on mine just make sure you get all the cables with it ,throttle and hot start cable, relocates it to clutch so ill have to get the perch with hot start. I got to take mine a short spin before my radiator started leaking and it was very noticeable.
  • zaxcar1
Posted June 10, 2013 - 04:59 PM
i do have the hot start there already
  • sid_125_04
Posted June 10, 2013 - 05:46 PM
Ok then the cables should be the same but still get one with all the cables just in case. Think I gave 200 for mine on eBay with everything 06-08 would be the way to go
Posted June 10, 2013 - 09:47 PM
The aftermarket cable kit for 426 hot starts won't fit a 450 carb.
The best carbs are any of the '05-'09's.
  • Zeppy1311
Posted July 19, 2014 - 08:07 PM
Ok so what makes them so special. Currently I have a jetting issue maybe I can benefit from the carb swap
Posted July 20, 2014 - 07:27 AM
What makes what special? The newer carbs?  They're a more advanced design internally.  The '05 and up have an accelerator pump leak jet so the pump can be more robust without slobbering gas into the engine when it's not needed.  Much better idle and part throttle performance, starting.  Much less fussy about little changes in the weather.
  • On January 15, 2017
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
  • Hot  28 replies
