Hot start issue
9 replies to this topic
  • Stealth13
Posted June 10, 2013 - 09:47 AM
Most of the time when my bike stalls I have to kick it into neutral then it fires up fine, if I leave it in first and pull the hot start once it a while it will start, but mostly it just keeps trying and won't start til it goes in neutral . What's the issue ?
Posted June 10, 2013 - 10:55 AM
Probably clutch drag (failure to completely release when disengaged). Is it fairly difficult to find neutral at an idle?
  • Krannie McKranface
Posted June 10, 2013 - 03:58 PM
If you are using a 'stock' battery, this is normal, due to clutch drag.
If you install a LiNi battery with 9amps or higher, it will go away.
You still should never start your bike in gear, unless it's necessary (side of a hill).
It's really hard on the starter clutch, starter motor, and battery when you do that.
Edited by Krannie, June 10, 2013 - 03:58 PM.
  • 080
Posted June 11, 2013 - 05:23 AM
Gotta ask, is it really that bad on them? I've always started my kickstart bikes in gear without any issue's and not really changed that habit with the Wr. What problems will it cause?
Posted June 11, 2013 - 06:11 AM
It has no effect on kickstart bikes.
E start bikes have more parts, more load, more 'weak links'.
  • Landcrab
Posted June 11, 2013 - 06:17 AM
Whew, had me scared for a moment, I kick my bike in first (accidently or just out of shear laziness) probably one out of every 50 kicks. No battery, which sounds okay.
  • 080
Posted June 11, 2013 - 06:25 AM
I figured that but has there been previous failure to any of these parts due to people starting them with the button in gear? No debate here just curious. My bike seems to turn over in gear with the clutch pulled in just as easy as if it were in neutral " But" I don't want to cause a problem down the road if this is an issue.
  • Thommo_400f
Posted June 13, 2013 - 09:25 PM
IF you have any clutch drag (mine does, so I have to find neutral) It simply puts more load on the starter motor, which draws more amps from the battery than usual. This in turn eventually kills your battery and stresses the starter motor to shorten its life.
Not a huge problem immediately, but best practice is to use your button in neutral, like Krannie said.
Posted June 13, 2013 - 10:37 PM
....or use your clutch and quit stalling all together...
  • Stealth13
Posted June 17, 2013 - 07:18 AM
Try riding the stuff I do without stalling....
I figured if the bike is very hot from slow tight trail riding it fires right up. But if it's been run on open trails keeping the heat down then I need to put it in neutral. 1 kick starts it every time though
