07 yz450f maintenance
5 replies to this topic
  • yz157
Posted June 10, 2013 - 08:26 AM
I just bought a 2007 yz450f and have no history on the bike. I'm pretty new to mx and even more new to four stroke bikes so please help! The bike is stock as far as I know other than an FMF pipe. I have rode the bike for a couple hours and it runs strong but stutters a lil bit at lower rpms. What should I do as far as maintanence before I ride more and how can I fix this stuttering issue? Any advise would be greatly appreciated.
  • etuke
Posted June 10, 2013 - 08:44 AM
air filter and oil change would be the first thing,look at the oil filter for metal,some aluminum is normal but magnetic chunks or brass filings usually not.I had to unplug the TPS on my 07 to get it to run smooth,its an easy try.Might also need a carb cleaning,I would buy an extended fuel screw , a magnetic drain bolt and a stainless oil filter as soon as you can.
  • yz157
Posted June 10, 2013 - 09:00 AM
ok I did clean the air filter this past weekend(it was extremely dirty). Where is the oil filter located on these?
Posted June 10, 2013 - 09:18 AM
Start here:
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
Then here:
http://www.thumperta...ad.php?t=852961
Then spend some time here:
http://www.thumperta...ssues-and-faqs/
  • etuke
Posted June 10, 2013 - 09:19 AM
right side just in front the clutch cover,you will see the lil round cover with 3 bolts.Bottom bolt is an alignment bolt,there is a sticky at the top describing on how to change the oil,sounds like you need to read it.
  • yz157
Posted June 10, 2013 - 09:57 AM
yes I do need to read it haha project for this week is just making sure the bike is safe to ride and up to date on all maintenance. I wanna do this before I hit the track again this weekend.
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
  • Hot  50 replies
  • Hot  113 replies
  • 5 replies
