Drz Gear shifter problem
I have a Drz 400 sm 2005 right.. The gears change fine and go up gear fine and down but when I knock it down gear the shifter gets stuck in the down postion and doesn't spring back up ? You have to nudge it with your foot and it clicks back into the normall postion gets very anoyying after a while help? Is there a spring somewhere what malkes it come back up
  • 2 months later...
  • 7 months later...
Yes there is a spring that can be worn. It works as basically a little wheel on a lever that fits into grooves on the shift drum that can eventually wear out and cause sloppy shifts. I believe you can get to it by taking off the left side cover and you should see the mechanism. (Someone correct me if I'm wrong on that)
  • 3 months later...
Hi everyone. Just put the cases back together and am stuck on the shifter.
Is a index mark but where does it go in accordance with the guts. Changes gears just fine till I get messing with spring thingy.
Forgive my terminology, will point screwdriver at it.
