Setting 2008 rear shock rebound
2 replies to this topic
  • SurfaceToAir
Posted June 03, 2013 - 04:50 AM
I swapped the stock springs back into the bike. The bike had Heavier Racetech springs before, and the previous owner had the front revalved. I am uncertain if the rear shock was touched aside from the spring..
Anyway, I am trying to figure out how to adjust the rebound on the shock. I didn't find anything in the manual explicitly stating how to adjust it on this shock, and reading the Internet it seems the low speed compression screw is a combination rebound and compression adjuster?
I need to adjust since the bike is kicking out and a little up on jumps this weekend.
The sag is all set, but I am scratching my head on rebound setting. I guess set the compression harder?
Any help is appreciated! I am literally losing sleep over getting the suspension sorted. Trying to wrap my head around how the bike handled and what I need to change next. :)
Cheers-
Dustin
Edited by SurfaceToAir, June 03, 2013 - 04:51 AM.
  • Krannie McKranface
Posted June 03, 2013 - 05:11 AM
It's on the bottom/side of the shock on the right side.
Remember, two clicks of the rebound affects compression approx 1/2 a click.
  • SurfaceToAir
Posted June 03, 2013 - 08:59 AM
Many thanks sir! I guess I was looking for a different looking adjuster down there. Don't know why I missed that screw! Its obvious now that I know that is it.
I am not sure why the manual doesn't cover this more. They wrote a page on setting the sag, but dont ( that I could find ) really identify location of low speed compression, high speed compression, or rebound screws. Perhaps the assume the reader will supplement the manual with Thumpertalk. :)
cheers!
Dustin
