Neutral Switch Sensor question 1999 WR400
2 replies to this topic
  • WildmanCafe
Posted May 31, 2013 - 02:26 PM
Can anyone tell me if there is a delete option for this or if it can be disconnected without causing problems. I picked up a '99 the other day and the wires are cut thru. All 5. Any help would be appreciated.
  • Do I Care?
Posted May 31, 2013 - 08:27 PM
Why not just rejoin the cut wires?
It can be bought cheap enough from partzilla.com click HERE anyway.
  • WildmanCafe
Posted June 01, 2013 - 05:39 AM
The neutral switch assembly is damaged itself. I've read that it's not needed. I'm going to find out today. I just need to fill up the oil and antifreeze and it's ready to start. I bought it this way and have been getting it back to rideable condition. It took a hit right in the area. Shift shaft was bent, footpeg brackets broke off and kickstand bracket boogered up. I refabbed the footpeg brackets, fixed the kickstand bracket, replaced shifter shaft and seal. Just need to fill up the oil and antifreeze.
