89 cr250r inner clutch basket?
3 replies to this topic
  • armpump257
Posted May 29, 2013 - 06:26 PM
long story short, broke a finger off the inner hub of the clutch while doing a rebuild (where the spring bolts screw into/what sets inside of the clutch basket) any ways iv been looking and there discontinued!? i cant find them anywhere, ebay,rockymoutain,motosport,honda, no where. Are any of the years of the basket the same? was the 89 trx250r the same? any one know where i can get one??? Thanks!!!!mAiZ3pRx3d39d5YjKZwzOiA.jpg
  • Jmmcrae
Posted June 11, 2013 - 08:48 PM
I did the same thing on a 86 cr250.
I found a used inner hub on ebay, it was from a 86 cr500. The cr500 clutch assembly uses the same parts as the cr250. Might give you a few more options.
  • armpump257
Posted June 12, 2013 - 05:29 AM
Thank you Jmmcrae! will do
  • bigpaul
Posted June 12, 2013 - 08:37 AM
You are searching for part number 22120-ML3-000[font="Trebuchet MS, Verdana, Helvetica, Arial, sans-serif"][color="#606060"][size=2] doing a reverse part number lookup on a online part supplier such as this:[/size][/color][/font]
http://www.hondapartshouse.com/oemparts/partsearch/honda_motorcycle
reveals that part number was used in the following Honda motorcycles:
1986/87/88/89 Honda CR250 and 500
What did you do with your CR today? by thetinkerer
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  77 replies
Honda Cr85 problem by Bashkillem69
  • Hot  30 replies
New to the forum. Question regarding cylinder scoring and break in by BlakeCR
  • Hot  50 replies
cr125 build questions by austin_honda
  • 7 replies
KP Racing Metering block - Dyno Results by CamP
  • Hot  370 replies
