Starting to pull the linkage apart and re-grease everything. The needle bearings come out of the linkage. What about the bearings in the swingarm. They seem to be sealed in the races. Do the needle bearings come out or just press grease in there with my finger?
lubing linkage
Posted 11 December 2003 - 07:06 AM
Posted 11 December 2003 - 08:43 AM
Don't forget to check the needle bearings in the bottom of the shock...
Merf
Posted 11 December 2003 - 11:21 AM
Posted 11 December 2003 - 02:49 PM
Posted 11 December 2003 - 03:25 PM
I have my swingarm laying on the kitchen floor, I will double check it when I get home but I think I'm right.
Or post over on the 250F forum and ask wrooster, he'll tell you for sure.
Posted 11 December 2003 - 05:28 PM
They all come out. All of the needles from the linkage, swingarm and shock will come out. Take them out carefully, clean them, and pack the bearing with grease and re-install them. Do one bearing at a time and keep your count on the needles as to not leave any out during the re-install.
Posted 11 December 2003 - 07:06 PM
Posted 11 December 2003 - 07:28 PM
Posted 12 December 2003 - 08:55 AM
Last time I did mine I just cleaned them with solvent and let them get good and dry then repacked with BelRay.
Also those bearings are kind of a pain to get out so I would just leave them in if all your doing is lubing them
Posted 12 December 2003 - 09:23 AM
a while ago i did a linkage re-greasing write up post (w/ pics) that will help you all out. and we integrated it into the 250F FAQ with even more info and more pics, including background on the yellow solid synthetic carrier that yamaha uses for production.
so click here:
http://www.thumperta...0&Number=447637
and then here:
http://www.thumperfaq.com/swingarm.htm
you will also want to read this thread:
http://www.thumperta...0&Number=482980
jim aka the wrooster
'01 wr250f
Posted 12 December 2003 - 11:56 AM
Also, I could not find that article about the steering head lube you did and I have seen mentioned. Where can I find that?
Posted 12 December 2003 - 12:12 PM
Cool "how to" on the linkage. You left out the part about the incredible mess. Friggen grease verywhere
Oh well . That's why this is a once a year project for me.
Posted 12 December 2003 - 04:51 PM
Quote
Posted 12 December 2003 - 05:28 PM
> the swingarm bearing needles which is what the question
> is about.
first, just a couple of definitions:
swingarm bearings are found at the ends of the swingarm.
linkage bearings are found on the "connecting rod" (bigger U-shaped part) and the "relay arm" (smaller L-shaped part).
the swingarm bearings have an inner race which holds the needles in place. see this pic:
http://losdos.dyndns...DSC00015_sm.jpg
hence the swingarm needle bearings stay put, but --
1) if the bearings appear to be in pretty good shape, just stand the end of the swingarm in solvent for a while to loosen things up. then blast them clean using the wand on your spray can of brake cleaner. let the bearings dry out, then pack them with waterproof grease(*).
2) if the bearings look crappy (rust etc), you will need to press them out and press in new bearings. yet another reason to keep up with regular maintenance.
on the other hand the connecting rod and relay arm bearings, as you saw in the pictures in the FAQ, are NOT captive. once the inner collar is withdrawn the needles are visible and can be removed.
from the yamaha factory all of the linkage bearings have solid lubricant, generically called "Microporous Polymeric Lubricant" or MPL. MPL is basically a polymer "sponge" which holds oil. you can read more about this class of lubricants here:
http://www.oilanalys...oup=Lubrication
here is a nice picture of the MPL in the bearing (thanks Av!):
http://mysite.verizo...sc/DSC00263.JPG
there are as many opinions on the MPL as there are members on TT. two things are for sure: 1) DO NOT USE SOLVENTS TO "CLEAN" the solid lubricant. you will just be drawing the entrapped oil out of the "sponge". 2) solid lubricants do not have good water resistance. to quote the article referenced above:
Quote
if you decide to keep the MPL in place, DO NOT USE SOLVENT TO CLEAN THE BEARING. just use a Q-Tip to get any dirt or debris out of the way, and then repack the bearing with waterproof grease(*).
http://www.thumperfaq.com/steering.htm
happy swingarm, linkage, and steering head servicing.
'01 wr250f
(*) here's an easy-to-do test for your "waterproof" grease...
pull on a pair of latex gloves. put a dab of your favorite grease in the palm of one hand. now run some water into the grease. use your other hand to swirl the grease around, and keep running water through the mix. if the grease turns whiter or milky or otherwise appears thinned or affected by the water, it ain't waterproof. only the best lithium complex base and most aluminum base greases will pass this trivial test. by and large, aluminum based greases have the best water resistance. bel-ray "waterproof grease" is an example of a good quality aluminum base grease.
http://www.belray.co...waterproof.html
Posted 12 December 2003 - 06:46 PM
I plan to tackle this project over the next week
Posted 13 December 2003 - 07:00 AM
Posted 13 December 2003 - 11:01 AM
