2010 yz450f
4 replies to this topic
  • scott elverud
Posted May 25, 2013 - 04:08 PM
Hard starting when up in the woods is it valve timing or could it be something else
  • BBrown626
Posted May 25, 2013 - 07:02 PM
  • kiwikawa
Posted May 26, 2013 - 02:18 AM
I have had this happen to me (2011 model) every now and again in the woods. I have just done all new valves and piston at 66 and valves at 77 hours
i have the technicque correct but it will just not fire, so i hold the throttel at "full open" and kick it 3 - 4 times, then let the throttel go "closed" and it will fire up on the first kick.
This is what i have found that works for me when i cant get the bike to start when in the woods.
  • zombiekillr.45
Posted May 31, 2013 - 07:45 AM
Hi there I own a 2010 yz 450 I am 5 ' 11'' and 170 lbs the only reason I mention my weight and height is im no big guy. I noticed this issue also the first ride ever on my yz but with a solid day of riding and feeling the best spot to throw all I got at the kick start she fires 1-2 kicks every time,I believe Yamaha has a video on proper kicking technique check it out helped me a lil
  • scott elverud
Posted May 31, 2013 - 10:07 AM
Thanks zombie that might help
  • Hot  36 replies
  • Hot  79 replies
Need help by Goforaride
  • Hot  68 replies
  • Hot  491 replies
