Strang oil contamination problem. Would like some input.
8 replies to this topic
  • f150jokerstyle
Posted May 24, 2013 - 07:54 PM
Okay so I got what I believe to be a weird one here. First a little back history to get us to the current "POSSIBLE" problem. The bike is an 03 yz450
About 2 years ago and around 100hrs ago now the bike was owned by a close friend. We were out riding one day and his bike seized up, piston to cyclinder. After cooling off it freed up but the damage was done. Opened her up and replaced the piston and rings and the cylinder had light aluminum transfer and was cleaned up with a hone.
Okay now she is all better right? Wrong about .5hrs on the bike and bang same problem. Once again tore it down and this time it took the cylinder out with it. This time we took it to a local machine shop to examine the failure and they suspected lack of oil pressure. Sure enough we dropped the screen on the oil tank "Bottom of frame fitting" and it was packed with what we thought was a blown out oil filter like material. We cleaned out the oil system with cleaners, compressed air, and flushing it all with oil. Of course replaced the oil filter again.
Okay now it has to be better right? Wrong about .5hrs in and bang seized up again. Okay now were like what the heck is going on. We inspect the screen on the oil tank agin and once again it's packed with stuff. This time we cut the filter in half and inspect for damage. None to be found. So we figured lets tear this sucker down to it's last bolt. Come to find out the clutch basket cushions were chunking off and clogging up the oil system. So this time we cleaned all the oiling system again, replaced the damaged parts and CLUTCH BASKET CUSHIONS and it has been running great ever since. We checked the oil tank screen every other oil change for quite a while after words and no problems to speak of.
Now to the present! I own the bike and have been racing quite a bit.
Lately the bike has been feeling like it's losing some of it's snap. I have been planing on doing a rebuild any ways but this last oil change I ran it on the same oil and filter about twice as long as my usual interval.(About every other ride) Well when I pulled out the oil filter It was a boring day so I really pulled it apart and looked into it. Guess what I found? The same stuff that was plugging it up as it did before.
So I pulled the oil tank screen and guess what it was 80-90% blocked/ plugged with that same stuff. So I pulled the clutch basket and checked the cushions. By the way this is a Barnett basket, So I unbolted the gear and removed and examined the clutch basket cushions and guess what? They were fine! So Now i'm at a loss. I cleaned everything and flushed it all out with clean oil the best I could. I removed the flywheel and stator to try and clean the oil pick up in the case the best I could but to say the least i'm pretty spooked out now!
What do you think the chances are a clump of that old stuff would maybe of just let go off the side of the tank and started circulating again? What are the chances that it is something els and what could it be? The color of the material in question is that of a some what clean used oil filter but the texture and consistency is that of say you were to take a skateboard wheel and hit it with a grinder and you took all the dust and chunks of thous grindings and you put it in oil.
We if you made it threw all that you deserve an award of some sort but the best I can offer is a like on any comments on this topic and give yourself a pat on the back!
  • f150jokerstyle
Posted May 27, 2013 - 03:31 PM
Any body out there :snore: I put one day of desert and one day of moto on it this weekend. I'm going to drop everything again this week and see if there is any more material build up.
  • NitrousR1
Posted June 01, 2013 - 07:54 AM
Post some pictures of this material so we can see it and maybe we can help you out
  • f150jokerstyle
Posted June 01, 2013 - 07:11 PM
To be honest I still have not opened it back up after I cleaned it out and put a few hours on it. I'v been busy as heck with work. But I have 2 bits of good news about that, I think I have all the money for my grand over haul I have planed and i'v been to busy to throw out the old oil filter that had all the stuff in it so I'll try and get some pics up of it tomorrow. Thanks for the response regardless.
  • zombiekillr.45
Posted June 02, 2013 - 07:12 PM
I woulda turned her into a boat anchor or ash tray the third seize lol I suspect the orig clutch rubber material crank cases and oil galleys can hide some amazing shit
  • f150jokerstyle
Posted June 02, 2013 - 08:35 PM
Lol at one point we where thinking about putting some peddles on it and making a pretty mean down hill bike out of it. I think your suspicions are on the money. I'm still working on the pics. This was my first day off in a while and the wife's list was deemed more important than mine.
  • f150jokerstyle
Posted October 12, 2013 - 04:48 PM
Finally getting back to this. Sorry for the delay bought a house and stuff. I know my priorities are not right, the bike should come first. Here are some pics of the material in question.
1383317_10202208088313757_493556048_n.jp
1382802_10202208085833695_215118660_n.jp
A few others,
1375675_10202208087073726_644522990_n.jp
1395439_10202208087753743_568194910_n.jp
Posted October 12, 2013 - 08:06 PM
Did you wash the frame out?
  • f150jokerstyle
Posted October 12, 2013 - 09:33 PM
After the problem was discovered a few years ago it was flushed out with cleaners and air and all sorts of stuff. Since then out of sight out of mind until I found this problem when I started this thread back in May. This time around there was much less build up but the interval was much shorter. I'm thinking at this point I just need to pull this screen out every other oil change and clean it. I really like the bike but it's an 03 and at this point I cannot justify the thousands of dollars I need to keep the bike going for the long haul. I know it needs a full rebuild and i'm running on borrowed time, at this point it's just not going to happen.
  • Hot  36 replies
  • Hot  33 replies
  • 9 replies
  • 0 reviews
  • Hot  47 replies
