From what I saw online there are 2 "drain plugs" for he rm250f but on the first picture below the drain plug for the "crank room oil sump" is just a tube? The second picture is the bottom of my bike..Cant I just empty the oil out of the one bolt on the left side of the picture? What is the other "drain plug"?
Changing oil.. 2 drain plugs? (RM 4 stoke)
Started by
taymag
, May 21 2013 04:42 PM
4 replies to this topic
Posted 21 May 2013 - 05:45 PM
Its appears that your bike is an older 04-06 steel frame. While the first pic appears to be a new aluminum frame bike. Motors are probably completely different. So just drain the one. Also the other plug on the above pic is most likely there. That hose is the coolant overflow hose.
Posted Today, 06:49 AM
Yes. Kawi has the same thing. If you just drain the main one you're leaving oil in the engine.
Follow us:
