2000 WR400F question
Started by
Strauser18
, May 18 2013 12:20 PM
8 replies to this topic
Posted 18 May 2013 - 12:20 PM
Hey guys I'm new to this suite and I have a few quick questions.. My 2000 WR400F doesn't have a air cleaner box cover, is this an issue? Also when I start the bike the only way I have good throttle response its if the cold start is on. When it is off, it sounds like a lag when I roll the throttle. I'm thinking about taking the carb out and cleaning it. Any help would be great.
Posted 18 May 2013 - 02:32 PM
I pulled my carb apart and cleaned it, I'll see if that was the problem, but still wondering if not having a cover for my air box is an issue.
Posted 19 May 2013 - 10:40 AM
Keep in mind blipping the throttle when bike is on the stand is different then when riding it. You can easily make the bike stumble by cracking the throttle quickly when just sitting in place. When you ride it its a different story. If it stumbles when actually riding then check the accelerator pump squirt timing.
Go to the stickys and check " How to Eliminate the Bog"
Posted 19 May 2013 - 05:44 PM
Most every one pulls the air box lid, snorkel thing off so the bike can get unrestricted airflow, it should not affect the bike in any negative way.
Posted 19 May 2013 - 08:49 PM
Thank you... I made an air box cover out of an old plastic lid. And screwed it down just to have a cover...
Posted Today, 06:55 PM
make sure you have some big holes in their to let the engine get air. The stock box lid has a hole in it about 2"x4".
you can probably google some pics of what stock looks like.
Follow us:
