2007 Dual Sport Kit
9 replies to this topic
  • quietoscar
Posted May 16, 2013 - 12:39 PM
I am installing a dual sport kit and have to remove the cover to get to the stater so that it can be modified. I have removed all the bolts that I can find but still can get it off. I was told that there is a magnet inside thats holding it but I cant seem to get it loose. Please help..what am I missing?
  • William1
Posted May 16, 2013 - 12:50 PM
The magnets on the flywheel 'pull' the stator cover on somewhat.
You opened the little cover and remove the starter gears, right?
Notice little cover #14 and the screw that is inside, #13?
  • quietoscar
Posted May 16, 2013 - 01:12 PM
Yep..got the little cover open, removed the starter gears and the screw inside, I think there were 3 others that I took out? Just cant get it to budge
  • quietoscar
Posted May 16, 2013 - 01:29 PM
Actually it was 7 other screws around the cover...2 from the starter gear cover and the 1 inside the gear cover
  • KennyMc
Posted May 16, 2013 - 03:27 PM
There are 3 screws inside that I believe you need to remove.
  • quietoscar
Posted May 17, 2013 - 05:16 AM
Thank you..I will try and look for them..I removed 7 screws around the outside, two on the cover and the one inside for a total of 10, just cant budge it. Does the magnet wire need to be disconnected as well?
  • KennyMc
Posted May 17, 2013 - 06:07 AM
Do you have the manual? There is a sticky on this forum that has the manual in a PDF form that you can download to your computer desktop. Comes in real handy. That's what I did even though I also have the hard copy.
It's under the "Performance Index" sticky above.
Edited by kenshaw720, May 17, 2013 - 06:10 AM.
  • quietoscar
Posted May 17, 2013 - 06:14 AM
Thank you..I do have the manual and thought I had everything disconnected properly but maybe not. I will look again.
  • quietoscar
Posted May 17, 2013 - 11:09 AM
Success!! Thank you for your help!
  • KennyMc
Posted May 17, 2013 - 01:51 PM
Which one were you "missing"? A helpful reminder. When you put back your stator, make sure to tuck the wires back behind the bracket. From what I hear :devil: if you don't, about 6 months later, somewhere deep within the Kennedy Meadows trail system, the flywheel can eventually rub through the wires :banghead: and your bike will cough, sputter and stop running. :cry:
