04 450 fork bump stops?
4 replies to this topic
  • gbalias
Posted May 16, 2013 - 09:53 AM
i imagine most years interchange but are the actual bump stops sold as a part of the spring guide or something along with the nylon washer? i cant find just the stops in any fische.
im rebuilding my buddies forks and the stops are dry rotted and cracking/broken
Posted May 16, 2013 - 11:05 AM
The '04 YZ450 used a 48mm open bath fork, which used oil locks for bottoming, and had no soft bumpers at the top of the fork. Do you inner tubes measure 46mm, perhaps?* If so, the bumpers are sold under KYB part number 110130000401. The '04 WR450 used the 46mm fork from the '03 YZ, and had these bumpers in them.
* Another visual clue is that the 46's will have a top cap that has a 19mm hex on a flat surface, while on the 48's the hex sits in a slight recess on the cap.
  • gbalias
Posted May 16, 2013 - 01:32 PM
Ah....correction....it is an 03....in which case that may be why i didnt see anything on the 04 Fische. Thanks.....ill look into it
Posted May 16, 2013 - 03:39 PM
If Yamaha doesn't sell them, SMART Performance and Suspension Direct will.
  • gbalias
Posted May 17, 2013 - 03:03 PM
yamaha has em at the dealer order only. so we'll just get them from online.
thanks again gray
