Leaking coolant
4 replies to this topic
  • nakkas
Posted May 14, 2013 - 11:38 PM
Help i'm leaking coolant from under the water pump from what looks like a cast hole. Why?
  • miweber929
Posted May 15, 2013 - 04:11 AM
Because your searching skills suck!!! :)
Been covered a bazillion times but your water pump seal is worn (and most likely the shaft as well) and your bike is nicely telling you to fix it by leaking coolant out a weep hole Yamaha designed to inform you of such.
Tons of how-to's on here. May even be some links in the pinned threads at the top of the forum.
  • Krannie McKranface
Posted May 15, 2013 - 05:32 AM
If your bike has been sitting for a long time, this is normal.
The seal gets a small flat spot in it, and it will weep.
The weeping may last for years before the seal goes out.
....but if it goes out 50 miles from the truck, well, then waiting to fix it means 'you choose un-wisely'...
  • GuyGraham
Posted May 17, 2013 - 05:34 AM
have a look here http://www.thumperta...k#entry10695504
  • nakkas
Posted May 18, 2013 - 06:44 PM
That's for your help. Still having major dramas trying to get the impeller off.
