Oil drain bolt .
2 replies to this topic
  • Stealth13
Posted May 13, 2013 - 06:13 AM
Finally got around to working on the bike after winter and did an oil change, the bolt on the left crank case had some metal shavings fall out. I tightened it by hand then gave it a small turn with the wrench. Will it be ok or think it will come loose and leak?
  • Hurky
Posted May 15, 2013 - 05:12 AM
Hi, the WR have helicoils in the drain threads so it's not that easy to wreck the thread on them, I suppose the metal shavings came from the transmission and not from the threat/bolt. "Smal turn" is relative, they don't need much force
• Drain bolt (crankcase right):
20 Nm (2.0 m · kg, 14 ft · lb)
• Drain bolt (crankcase left):
I would reccomend you to get an magnet drain bolt that catches those metal shavings...
  • bobpara
Posted May 15, 2013 - 12:00 PM
Although the magnet will do nothing to catch aluminum shavings, they are not magnetic.
