Repacking the Stock Silencer
2 replies to this topic
  • Fruitfarmer231
Posted May 12, 2013 - 07:41 AM
Did a search and nothing came back, I've got my silencer on the 05 WR450 pulled apart and have been attempting to repack and stuff it back in the cannister. Couple things first if you ever considering tackling this yourself. 1. The baffle/cartridge can be inserted upside down so confirm the correct orientation. There is some interference with the spark arrestor if you intend to reinstall, 2. the room between the cannister and perforated canninster/insert is minimal, room for only about a 1/2 layer of packiing,, and a real SOB to reinsert. I've followed some repacking videos, and the "core" on those silencers is much smaller and apparently make reinstall a simpler process. In fact I am about ready to go purchase an aftermarket silencer and pitch the whole works in a can. If you have done this and can suggest some tips, I'm sure any rider contemplating this would also appreciate it.
Thanks,
  • GuyGraham
Posted May 12, 2013 - 08:21 AM
Stock silencer isn't an absorption type and hence doesn't need re-packing as it doesn't degrade over time
Its known as a mechanical baffle, as the sound level is reduced by the different chambers within the silencer each targeting specific frequency of sound
There is a small amount of wadding just inside of the cans' internal surface but I don't think you'll be able to replace it
  • Krannie McKranface
Posted May 12, 2013 - 02:25 PM
Thanks,
What you are describing is not a stock muffler.
You get the perforated tube to line up correctly, it's easiest to remove the rear cone of the muffler. This may require drilling out the rivets, and replacing them with screws.
To get packing to fit, use safety wire to hold the packing in place by wraping it around the whole fiber stuffing; just enough to hold it in.
