Engine Removal Required?
3 replies to this topic
  • wweagleflyer
Posted May 12, 2013 - 06:23 AM
Just curious, for a 2006 yz 450f, do you need to remove the engine in order to remove the head, cylinder & piston? In particular, I wonder if the 4 long head bolts would interfere with the bike frame as you try to pull them out. Is it more trouble than it is worth to try to do a top end replacement without removing the engine from the bike frame? Couldn't find an explicit answer to this on the forum.
Thanks
  • mpmoto
Posted May 12, 2013 - 06:38 AM
200% you don't need to remove engine
Posted May 12, 2013 - 07:07 AM
It can be a little bit challenging, but not enough to make me want to pull the engine.
The head bolts that interfere can be removed when the head comes loose by tilting it after it's clear of the aligning dowels, or take out with the head. Same going back together. The front chain guide can give you a little trouble, too.
  • wweagleflyer
Posted May 12, 2013 - 07:25 AM
Thanks
  • 5 replies
  • Hot  113 replies
  • Hot  38 replies
