BurRaaap Fest
6 replies to this topic
  • Guest_Guest_*
Posted April 26, 2001 - 08:26 AM
Since there are a million earthfests going on this weekend and everyone will be driving around and things will be buisy, let's make sure we all get out and ride. It will be a great day to get out and appreciate the trails we have on our lovely planet. I am riding in New Hampshire if anyone is interested. I'm having a BurRaaap Fest!
  • BigDog
Posted April 26, 2001 - 10:53 AM
I will be doing the same in Minnesota. Expecting temps in the mid 70's.
  • Guest_Guest_*
Posted April 26, 2001 - 11:23 AM
We are in mid 70's weather here as well. We hit 80 last week. It was tooo hot.
  • Guest_Guest_*
Posted April 26, 2001 - 11:25 AM
What are you talking about? This last Sunday it was 101 degrees at the desert where I go in SoCal. Almost too hot. I think I can squeeze another weekend or two out of it.
Khris
When in doubt, GAS IT!
What are you, YELLOW?
  • Guest_Guest_*
Posted April 26, 2001 - 11:26 AM
Id F'N melt. It was 65 yesterday and sweat was dripping into my goggles.
  • MN_Kevin
Posted April 26, 2001 - 11:45 AM
Mike,
My carb is in pieces as we speak. I have (Oh my gosh) drilled out the main air jet and port as per Taffy's (David's) instructions. I will be running an FHP needle, air screw (Yes, air screw from Sudco), and a 168 MJ (JD recommended a 170, which I don't have).
Now I am trying to limit the travel on my NON ADJUSTABLE accelerator pump, using a washer setup.
I hoped to drain the oil out of my Pro Action jack hammer forks, and use an ultra lightweight (2.5) oil AT MINIMUM LEVEL. Hopefully, I won't have to get that Carpal Tunnel Surgery that comes with each Pro Action rebuild :)!
I am ready to rock and roll, though! Any new areas to ride?? How 'bout Jolly Roger MX track...???
'99 WZ with all YZ mods, de-octopused, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, forked over by Pro-Action, OEM YZ tank, IMS YZ seat, carb mods by Jim Dean and Sir "Taffy" from Jolly Old England, AMA, NESC.
  • Guest_Guest_*
Posted April 27, 2001 - 02:37 AM
I got trails you have never seen! You let me know when you are ready.
