WR426 clutch cable replaced, clutch wont disengage
12 replies to this topic
  • Boerboel
Posted May 09, 2013 - 07:18 PM
After my old clutch cable severed and left me stranded, I replaced it with a motion pro cable today.
I got it in no problem and did my first adjustments. With the bike on and in neutral i pulled the clutch and dropped it into 1st, i slowly let the clutch out until it started to engage and everything seemed fine. I went on a short ride up to 3rd and came back down to 1st and no matter how hard I pulled the clutch the bike tried to crawl away in 1st.
I keep adjusting up at the handlebars and down by the motor, and I keep getting the same result. The bike wont roll with the clutch pulled while off even if warm. all test where done to a warm bike. Help!
  • Krannie McKranface
Posted May 09, 2013 - 07:20 PM
Pull off your clutch cover, and look at the basket and plated.
You probably have a extremely notched basket, or, a broken plate, or a plate that has shifted.
  • Boerboel
Posted May 09, 2013 - 07:26 PM
thanks, ill go give that a shot. I can tip it over and remove the cover without losing the oil right?
Posted May 09, 2013 - 07:31 PM
Yup
  • Boerboel
Posted May 09, 2013 - 08:31 PM
I went back to mess with it before pulling the cover off and found that when it tries to crawl away, if i brake to a complete stop it will stop crawling and idle normally... Im running 10w40 Yamalube
  • Boerboel
Posted May 09, 2013 - 08:39 PM
Pretty sure this picture is useless, but I wasn't going to dig into the bike any further.
Posted May 09, 2013 - 09:36 PM
Are you trying to test the clutch when it's cold, in your driveway?
The clutch has to get hot first................
I think you are looking for something that isn't there....and you are dealing with a 10+ year old set of plates and fibers...with plate probably being a mm or so warped.
  • Boerboel
Posted May 10, 2013 - 12:26 AM
I realize the clutch has to get hot first, which is was the bike was warmed up during anything i did to it.
What im looking for is the reason my clutch doesn't fully dis-engage until i force it to a complete stop via the brakes
Posted May 10, 2013 - 06:05 AM
I've never experienced a WR clutch to not drag a little bit.
  • woods-rider
Posted May 10, 2013 - 06:09 AM
Yeah, completely normal. Once it gets hot the problem should go away.
  • Boerboel
Posted May 10, 2013 - 04:22 PM
it doesnt go away while warm, but i fixed it today by buying a 2012 WR450... quite the expensive fix.
  • fdme
Posted May 10, 2013 - 04:24 PM
LOL, I like the way you solve problems.
Posted May 11, 2013 - 12:08 AM
The 426 had it's run. Time for the new blood.
