Skid Plate suggestion on 12/13 WR450F
26 replies to this topic
  • albertlui
Posted May 09, 2013 - 12:41 AM
GYTR, Devol, Moose, etc. Any comment on them? In terms of coverage, hardness, easy to install, drain oil without removal, etc. Thanks!
  • BMWbeej
Posted May 09, 2013 - 02:25 AM
I've got the GYTR enduro(without the holes) bash plate and am very impressed! Does collect a lot of mud on it's upright face though...
  • 080
Posted May 09, 2013 - 05:57 AM
I like the way the plastic ones wrap around and the coverage they give but put a Hyde on my last bike and wasn't to impressed (ended up cracking after a couple months). Was looking at the TM Designs and the coverage on theirs looks real good, probably going to give it a try. I'm thinking with the good reviews they get their quality of plastic is better????
  • JDLowrance
Posted May 09, 2013 - 08:25 AM
I bought a couple of the Acerbis plastic skid plates for my 09 and it transfered right over to the 12. Good coverage (probably not as good as some of the full wrap aluminum ones), easy to remove and replace, quiet and doesn't collect mud once some open cell foam is in place. Eassiest to remove when changing oil but takes less than a minute to R&R.
  • GP1K
Posted May 09, 2013 - 08:30 AM
Still running the stocker til I see a reason to change. Anyone 'tested' their stocker and found it lacking?
  • jerejim
Posted May 09, 2013 - 03:01 PM
The GYTR one just looks cool.. I like mine.
  • albertlui
Posted May 09, 2013 - 06:24 PM
Thanks all, i like the GYTR too. I always climbing on rocks, and afraid the plastic skid plate not hard enough to protect the frame and water pump.
Is that means up to now, all new skid plates need to remove when draining oil? I have a B&B skid plate with my 06 WR, the shape like GYTR, and it has a hole at the bottom and can drain oil without remove it.
  • D-rek07
Posted May 09, 2013 - 06:38 PM
I have an MSR one but now they only make one for the YZ. I don't know if it would fit.
  • Ricky Roma
Posted May 11, 2013 - 04:24 AM
I have run the stocker for a year now. Have given it a hard time over logs and it has held up fine. I do not ride in terrain with large rocks though.
  • ONARAYLE
Posted May 11, 2013 - 08:28 PM
My stock plastic one didn't make it through the first ride without cracking at the first sign of a rocky climb. I've torture tested the gytr and it holds up great. You can always drill a 1" hole under your drain plug but you still should take it off to get to the left side drain bolt.
  • mobgma
Posted May 14, 2013 - 06:09 PM
Hyde Racing
  • Mlc450f
Posted May 16, 2013 - 01:05 PM
GYTR on my bike. I like the fit! Would prefer more drain holes.
  • KennyMc
Posted May 17, 2013 - 06:03 AM
I have run the Flatland one on my '07 since day 1. Was so impressed with how well it held up I just replaced it with a new one.
  • RSWR450F
Posted May 22, 2013 - 02:18 PM
ACERBIS skid plate WR450 2012-13
Left ORIGINAL WRF, right ACERBIS:
on bike:
  • KennyMc
Posted May 22, 2013 - 03:44 PM
One thing I like about the Flatland Racing skid plate is it wraps all the way around the water pump. It comes up to that little plate at the base of the tube. The Acerbis one stops below it based on the pictures above.
  • Navaho6
Posted January 21, 2014 - 12:31 PM
How about Works Connection and ACD Racing skid plates?
Works Connection is $125 at Rockymountainatv.com.  No thickness given.  Holes cut to drain oil without removing skid plate. Connection allows frame flex.
http://worksconnecti...return=--WR450F
wor_14_ful_con_ski_pla_wit_rim-146530000
ACD Racing is $110 on ebay. 4mm thick.
http://www.ebay.com/...c#ht_2401wt_900
  • vlxjim
Posted January 21, 2014 - 01:14 PM
I just got one of these.
Would you still foam this one or use rubber between the mount? I have not received it yet do you this its going to be noisy? It does look nice though.
Edited by vlxjim, January 21, 2014 - 01:16 PM.
  • Navaho6
Posted January 21, 2014 - 02:33 PM
Looks like more chance for a rattle on the the ACD but that would be an easy fix.  Also looks like the Works Connection might have a little better protection for the water pump.  Nothing wrong with the ACD.  I actually like all the holes in the bottom.  Should make it easier to wash all the trash out.  I'd use foam on both.
  • albertlui
Posted January 22, 2014 - 06:32 AM
finally i bought works connection, not see any problem so far
  • foggy3061
Posted January 22, 2014 - 11:46 AM
It looks like ACD might make sump guards for Yamaha too - I bought a GTYR sump guard and it looks a lot like that ACD one!
I had to modify it though, as where i ride in the UK is all rock and was causing serious damage to the guard in standard form. The holes in the underside allowed it to bend in when faced with big impacts. I added four corner braces, more coverage up front and filled in a lot of the cut outs. Now it looks like this:
