Got my but in gear. (Rebuild)
22 replies to this topic
  • sid_125_04
Posted May 08, 2013 - 05:44 PM
ImageUploadedByThumper Talk1368063713.472528.jpg ImageUploadedByThumper Talk1368063738.351744.jpg ImageUploadedByThumper Talk1368063762.338823.jpg
Got my but in gear, built a powder coater oven.... Lot of goodies to go on and reason for full rebuild was no 5th gear.
  • four-twenty-sixer
Posted May 08, 2013 - 06:48 PM
That looks awesome!!!
  • sid_125_04
Posted May 10, 2013 - 12:59 PM
Thanks I hope it turns out ok. Motor upgrades are both hot cams and fixed fifth gear. Also I picked up a 08 450 carb and i am excited about that one. Also suspension done by fcr for my big but 6' 240. More pics to follow over weekend.
  • woods-rider
Posted May 10, 2013 - 01:13 PM
What did you use for the oven? Must be a decent size to fit the whole frame into.
  • sid_125_04
Posted May 10, 2013 - 05:41 PM
Um yeh u guys are gonna laugh ur asses off ill post a pic but its a old chest freezer I converted lol
  • four-twenty-sixer
Posted May 11, 2013 - 05:19 PM
Can't wait to see it, was wondering what you were using.
  • sid_125_04
Posted May 12, 2013 - 02:10 PM
Heres my oven go ahead and laugh i am! But it works
ImageUploadedByThumper Talk1368396526.203527.jpg ImageUploadedByThumper Talk1368396544.753593.jpg ImageUploadedByThumper Talk1368396561.232347.jpg ImageUploadedByThumper Talk1368396589.085882.jpg
  • four-twenty-sixer
Posted May 12, 2013 - 02:17 PM
Good idea, I wouldn't think that could take the heat.
  • sid_125_04
Posted May 12, 2013 - 03:53 PM
The old freezers are all metal and I lined it with 26 ga steel also . We do hvac so I can do this stuff all my self and it was at 400 and u can touch all sides no problem
  • sid_125_04
Posted May 15, 2013 - 05:36 PM
Ok got some more together. Also i dont have any wheels.... Major part to ride... Anyway wondering what everyone think on wheel and color choice let me know i should get the graphics on soon.ImageUploadedByThumper Talk1368668090.223480.jpg ImageUploadedByThumper Talk1368668126.892624.jpg ImageUploadedByThumper Talk1368668149.560630.jpg
  • G-BRO
Posted May 15, 2013 - 08:03 PM
This looks incredible so far. Nice touch on the black valve cover and the blue timing covers. I also like the white fender. Where did you get the radiator braces? Can't wait to see this when its done
  • sid_125_04
Posted May 16, 2013 - 04:18 AM
The braces are "unibiker" and im not impressed what a pain to put on. Especially with the over sized radiators! Also then your cables dont run right and its very tight when u can get them through. Had to cut the left side one to accommodate the oil line. Instructions said to add washers to clear oil line....... Really?! I hope this thing turns out all right....
  • G-BRO
Posted May 16, 2013 - 06:34 AM
Good to know. Reason I ask is because I also have an oversized radiator and I couldn't find anything that fits. Did you do any top end work on this bike and if so what brand parts did you end up with the major components? That's next on my bike. Good luck!
  • sid_125_04
Posted May 16, 2013 - 08:28 AM
No the bike has been sitting in a barn from 08 to 11 when i got it and iv had it torn down for seance then. The motor was solid found a few bearings starting to go so i replaced them. Had to get a set of hot cams and i took the compression release and slammed it in the trash!
Those radiator braces are a pain to put on but im confident if i wreck bad they will still be intact.( for what thats worth)
  • sid_125_04
Posted May 22, 2013 - 05:09 PM
Ok graphics on and im gonna have to get new number backgrounds again i suck at putting them on! Still need suggestions on wheel and hub color.ImageUploadedByThumper Talk1369271251.095201.jpg ImageUploadedByThumper Talk1369271297.964993.jpg ImageUploadedByThumper Talk1369271323.836950.jpg ImageUploadedByThumper Talk1369271343.063168.jpg
  • sid_125_04
Posted June 06, 2013 - 04:02 AM
Ok so i got my wheels mounted to new Dunlop's yesterday stayed up and got the bike together and put some engine ice in it and the seals on the solid pieces that go in the engine were leaking luckily i had extra ones. Get that done then put some fuel in it and the seals in the petcock had dried out.... So drain the fuel luckily i have extra seals for that also... But this time I'm just about over it. So i get it started and take her a spin.... And wow how i have missed this lil devil. Took and short ride put it in the garage and engine ice is dripping out everywhere couldn't pin point it. So i ordered new seals for the radiator pieces. Now this radiator came with a 1.1 cap. And its an over sized radiator. Went ahead and drained the fluid to see how much i actually lost and it wasn't much, so I'm thinking i need a higher pressure cap. Any other suggestions?
  • BGoyins
Posted June 06, 2013 - 04:27 PM
My 2 cents on wheel/hub color. Blue anodized hubs, matching blue nipples, black Excel rims with white lettering. I think a true white hub with black rims would look cool, but I don't think the aluminum hubs can be anodized that color... not sure about that.
  • sid_125_04
Posted June 06, 2013 - 05:04 PM
Yeh that sounds nice but outta my price range went with black on black and it looks sweet. I'll try and get some final pics this weekend. Has anyone had trouble with the seals beside the exhaust for the radiator?
  • BGoyins
Posted June 07, 2013 - 04:20 AM
I can't afford that either! I was hoping to live vicariously through your purchases, haha. I look forward to seeing your pictures... really nice bike.
  • sid_125_04
Posted June 13, 2013 - 04:44 PM
Ok found the radiator problem.... I tightened a hose clamp up too much and it put a hole in the rad. Nothing JB weld couldn't fix. So after i got that fixed and ironed out... Got the wheels on and as grayracer said the dna wheels are cheaply made....and i will be getting excel rims and sand blasting factory hubs and powdercoating them to replace the dna's. so here is the finish product. I did ride around the farm for bout 1/2 hour last night to make sure everything's good also a pic of the fixed radImageUploadedByThumper Talk1371170406.102705.jpg ImageUploadedByThumper Talk1371170428.394627.jpg ImageUploadedByThumper Talk1371170474.997560.jpg ImageUploadedByThumper Talk1371170538.457357.jpg ImageUploadedByThumper Talk1371170573.537991.jpg ImageUploadedByThumper Talk1371170611.348412.jpg
  • Hot  36 replies
  • 9 replies
  • 0 replies
