How do I install water pump bearing in yz450f 2008
6 replies to this topic
  • Codyy91
Posted May 07, 2013 - 04:33 PM
Do I have to take the crank case off
  • wweagleflyer
Posted May 07, 2013 - 04:42 PM
http://www.thumperta...0-coolant-leak/
  • Codyy91
Posted May 07, 2013 - 05:02 PM
Hey thanks I guess this weeping hole leak shit is pretty common in these bikes I bought a new case an Impeller thinkin that would work but it didn't so I realized there's play in the impeller shaft which means its a bearing right? So I bought a bearing and oil seal and the other seal
  • aja342
Posted May 07, 2013 - 11:29 PM
Yeah, I replaced the seal, shaft and bearing on my '06 twice and did it on a friends '09 once. I am sure it is best to replace all the peices at once. It is not hard and does not take more than an houre if you use the manual.
  • Codyy91
Posted May 08, 2013 - 12:18 AM
Yea I gotta get a manual
Posted May 08, 2013 - 06:44 AM
Water pump how-to:
http://www.thumperta...ad.php?t=940018
Manuals:
http://www.yamaha-mo...uals/index.aspx
http://www.yamahaown...ook.com.au/?r=0
  • Codyy91
Posted May 08, 2013 - 01:32 PM
Thanks for the links!
