Off timing? (see picture)
24 replies to this topic
  • peter10
Posted May 05, 2013 - 06:25 AM
#21
Just had to turn the engine over one revolution, you were checking the cams on the wrong stroke.
So the timing is okay?:
Posted May 05, 2013 - 10:35 AM
#22
This is how it supposed to be?
No. Now the intake is backward.
  • cr8ter
Posted May 07, 2013 - 10:43 PM
#23
the cam lobes should point away from eachother and dots on the gears should be level with the top of the head.
  • cr8ter
Posted May 07, 2013 - 10:49 PM
#24
u have any pics of where u have the timing marks lined up to on the bottom end? If your're not sure of tdc you can put a screw driver in the spark plug hole and turn the crank over until the screwdriver stops moving up. Once it stops going up you are at TDC. Also double check the timing marks on the bottom end to ensure marks line up.
  • peter10
Posted May 08, 2013 - 06:10 AM
#25
I put the screwdriver in a spark plug hole aswell,also checked the marks.it was definately on TDC
  • Hot  33 replies
  • Hot  79 replies
  • Hot  36 replies
