Oil leak from clutch actuator
3 replies to this topic
  • ssandijss
Posted May 03, 2013 - 02:57 AM
Hello!
I have a Yamaha yz450f '07.
I found oil leak from the clutch actuator? Oil seal is damaged? It happened after a day in realy muddy track..
How can i change the seal?
I understand that i need to remove actuator, but to do that, do i need to remove clutch basket or is it some screw somwhere?
  • Yamaryder29
Posted May 03, 2013 - 03:32 AM
If I remember correctly, all you have to remove is the pressure plate, the push rods and ball bearing. Then you should be able to lift the actuator up to replace the seal.
  • KJ790
Posted May 03, 2013 - 05:47 AM
Correct, you need to pull the pressure plate and the pushrod. Then you can remove the actuator arm. The seal is held in with a snap ring so you will have to remove that to get the seal on. It's not too hard to fix.
  • ssandijss
Posted May 04, 2013 - 08:56 AM
Thanks! It really was not difficult!!
