Axle blocks ?
8 replies to this topic
  • Twistedwrench
Posted April 28, 2013 - 04:53 PM
Just got my Ride Engineering AB in the mail and they are a bit smaller than the OEM ... Will this cause an issue or not? ImageUploadedByThumper Talk1367196802.303827.jpg
  • YZPaGuy
Posted April 28, 2013 - 05:44 PM
That doesn't look right. I have the same bocks for my 08 YZ450F except in red. They fit tight. Looks like they sent you the wrong blocks.
  • Twistedwrench
Posted April 28, 2013 - 06:17 PM
I guess my question is will it cause the swing arm to wear?
Posted April 29, 2013 - 06:04 AM
It's not a problem. The axle blocks bear none of the bike's weight, and they aren't supposed to contact the swing arm on their top or bottom sides. (the OEM blocks don't either)
  • Twistedwrench
Posted April 29, 2013 - 08:10 AM
Thanks.. I can't send em back cause their mounted so.. Thanks for easing my mind!!
  • DGXR
Posted April 29, 2013 - 08:56 AM
But with that much clearance, won't the axle block twist when the axle nut is tightened, causing the chain adjustment to move?
Posted April 29, 2013 - 09:04 AM
The block doesn't look twisted, does it? The visible clearance between the overhanging ledges cast into the swing arm is deceptive. The OEM blocks, as I said don't touch this area either. Instead, the fit into a much shallower machined step in the vertical surface of the slotted axle tab.
  • Twistedwrench
Posted April 29, 2013 - 10:21 AM
Those are tight.. I ran a rag through the sprocket before tightening down and no issue.. Just was curious about axle wearing on swing arm .. Wasn't sure if the blocks help disperse the shock through the arm instead of concentrating it on the hole.. But after lookin at the OEM blocks .. Yes there is a gap.. Just not as pronounced..
  • YZPaGuy
Posted April 30, 2013 - 05:01 PM
I'm going to look at mine closer tomorrow. Chalk another one up to me not knowing SH*T! LMAO
  • Hot  50 replies
  • Hot  38 replies
  • 5 replies
  • 0 replies
  • 10 replies
