Anyone given their WR426 a Diet??
15 replies to this topic
  • 696
Posted March 25, 2001 - 04:56 PM
I am looking very hard at a WR426F but, I'll be gaining 10lbs. has compaired to my DR350. I was thinking of taking off the headlight and use a YZ number plate and change the rear fender with a YZ as well. Any other ideas on where to cut weight and I would like to keep the cost low. I've seen the carbon fiber stuff but it's to pricey :)
696
  • Bill
Posted March 25, 2001 - 05:03 PM
This very topic was discussed in length not long ago. Do a search using the user name Dougie. It was about a month ago.
I think you'll find that the power difference in the two bikes will make the dub-R feel lighter than the DR.
Some popular thought and mods:
YZ number plate
Remove odo (use YZ spacer and seal at odo drive)
Remove kickstand
Aftermarket exhaust (wait for a quite one)
Aftermarket handlebars
Bill
97 KDX220, 86 TTR225, 99 WR400f, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. De-octopussed. Works frame guards and Thumper Rad Guards, Scotts steering damper. Odometer and headlight removed. Moose hand and mud guards. YZ stock tank, IMS seat and number plate. Renthal Jimmy Button "highs" and Renthal Soft half waffle grips. AMA, SETRA, Happy Ramblers MXC.
  • Marty
Posted March 25, 2001 - 05:05 PM
But at the same time you are gaining 76cc Im not sure on the power of the dr350 but I would think that 76cc would make up for the 10lbs with power. But if you are worried about removing weight number plate and rear fender a start and almost the only thing you can do that wont cost you an arm and a leg.
Marty
  • Marty
Posted March 25, 2001 - 05:07 PM
No fair Bill you hit the submit button faster then me. :>
  • WR400inOZ
Posted March 25, 2001 - 05:37 PM
You could try losing 10Lbs @ the gym??
Seek the Thumpertalk pages and you shall find just about anything you need to know about the DubR's
  • 696
Posted March 25, 2001 - 09:25 PM
Nah,between going to the gym and riding a WR426F I, personally would GAIN more that 10lbs. :) :D
  • Guest_Guest_*
Posted March 26, 2001 - 03:28 AM
I try and take a big dump. I think I have lost up to 5lbs before a ride. On a serious note, a 426 diet can get very expensive, but the stuff is out there. Carbon, Aluminum, titanium, you name it.
  • olson_jr
Posted March 26, 2001 - 09:53 AM
I took the big step from a DR350 to a 99 YZ400F. Don't even think twice about the weight. The suspension works so much better on the WR/YZ's that you won't even notice 10 lbs.
Go for it! You will be glad you did!
  • flyingboy
Posted March 28, 2001 - 05:45 AM
Bill, I did a search on the thread w/ Dougie and couldn't find it. Other than the exhaust, what parts are the best to replace with cf/titanium for weight?
How about the rear sprocket? Is the stock one steel, or aluminum?
Is the WR subframe aluminum like the YZ?
  • Bill
Posted March 28, 2001 - 05:55 AM
Search again using Dougie, the post was on 1/26/2001.
The stock rear sprocket is steel. I running an aluminum 52t now, to try the gearing and when it and the chain gives up. I'll be using the sidwinder stainless steel sprocket.
The WR subframe is steel, YZ aluminum, GYT-R titanium (appx$500).
speed is money, how fast can you afford to go :)
Bill
  • Mitch_from_Oz
Posted March 28, 2001 - 05:32 PM
Hey there 696.
Never weighed the WR400 after the mods, but some basic mods I have performed are as follows:
- Titanium DSP Pipe and exhauist
- DSP carbon airbox + velocity stack
- Alloy sub-frame
- Bars
Where I have added weight:
420 kit
Hydralic clutch
Vortex ignition
19" rear wheel
Anyway, good luck
Mitch
  • flyingboy
Posted March 29, 2001 - 06:48 PM
Hey Mitch, how do you like your DSP pipe/exhaust? I'm thinking about a Yoshimura titanium. Where did you get your alloy subframe, and for how much? Are the titanium Yamaha subframes durable?
  • Clark_Mason
Posted March 29, 2001 - 07:52 PM
I put every CF and Ti part avaliable on my WR420 and dual sported it with a Baja designs kit. In street trim it weighs 252lbs.
Some of the itemes added all ti and aluminum fastners including the SW pivot, axels, and linkage bolts. CF skid plate, side panels, fork gards, other gards, clutch cover, mag cover engine mount brackets, seat brackets, etc. Other ti items: subframe, footpegs,---anyway can't remember all the stuff on it.
The bike bone stock with no fuel on my scales weighed 264lbs now dual sported with handgards etc. it weights 252lbs, Its you basic $10,000+ WX420.
Clark
  • flyingboy
Posted March 30, 2001 - 06:34 AM
Clark, where did you get all the titanium bolts and fastners? Are they Yamaha pieces?
  • Jemtec
Posted April 07, 2001 - 12:56 AM
Gtyr 2001 Catalog has lots of Titanium goodies for the WR. 3 different kits all totaling a hefty price tag. The only one Id spend the Money on is the Chassis Kit myself. Maybe the engine kit.. but not anything else. Just my .02.
Have a blast.
  • Howard_Huge
Posted April 09, 2001 - 04:59 PM
Titanium shock spring loses two (2) pounds over its steel counterpart. If you have to ask...
enlightened, huge
