fuel in engine
7 replies to this topic
  • jsayre13
Posted April 19, 2013 - 03:14 PM
So my 2002 yz426f was having problems starting recently. Before this I have always gotten it started in 2-3 kicks. it was hard starting for a couple weeks then (at the track) just quit and will not start.
Things ive checked: carb is getting fuel, New spark plug. When I took of the inspection covers to check for valve clearance (which were good) I got about a gallon of gas out of the engine case.
Ive got the carbs out to clean them now. any other ideas on what could be happening? I'm at a loss!
Posted April 19, 2013 - 03:29 PM
Oopsy, your float stuck (or something). The gas likely got into the crankcase by having the float needle allow a slow flood while the bike sat with the gas on. Float level was high enough to drool gas into the intake without rising far enough to run out the overflow tube.
  • jsayre13
Posted April 19, 2013 - 04:00 PM
I'm thinking I may need to re build the petcock in addition to the carb cleaning...
  • EdgeR6
Posted April 19, 2013 - 04:22 PM
i love some of the subject lines. usually u want gas in the motor..
  • jsayre13
Posted April 19, 2013 - 04:37 PM
Ha, so true. ;)
  • jsayre13
Posted April 22, 2013 - 06:58 PM
Put carb back together. Drained oil that had the gas mixed in it and found this. Still can kick through without using decomp lever. Rings? Not sure where to go from here.
  • zeuszuki
Posted April 22, 2013 - 10:21 PM
Do you have a photo from other side?
On the "flooding" issue. On carbs that have a removable float seat ALWAYS replace the O'ring seal. They flatten out and stop sealing 100% , this allows fuel to bypass the needle and seat. Your needle and seat could be working perfectly but it will allow fuel into the bowl and then into your engine - result ,fuel in your oil. I have drained as much as 16litres ( about 4 gallons) of fuel out of individual engines over the years because of this fault !!!
Edited by zeuszuki, April 25, 2013 - 03:12 PM.
  • jsayre13
Posted April 25, 2013 - 01:40 PM
Found where piece came from. Putting new piston rings in too while engine is pulled.
  • Hot  50 replies
  • On January 15, 2017
  • 0 replies
  • Hot  28 replies
