Who's Changing Out Top Ends?
7 replies to this topic
  • RichB
Posted November 21, 2001 - 04:38 AM
Hey guys,
How often are you guys replacing the top end in the 426. I bought a used 01 and DO NOT want to pay the expense of fixing a blow up on a thumper. Am a little bit nervous from coming off a 2-stroke where I knew to replace my top end once a year (never blew up a bike in over 10 years). How do you tell when it's time, other than waiting for a catestrophic event.
Thanks
  • Glen_T
Posted November 21, 2001 - 05:36 AM
I replaced mine after 2 years. General principles. Piston was a bit worn, but could have gone longer. This bike gets an average of two solid rides a month. (wish it could be more)
GLEN
  • Greg
Posted November 21, 2001 - 06:42 AM
I have approximately 100 hours on my 2000 426 and it is still going strong. I regularly change my oil and service my air filter. I think the compression test is the best method to determine top-end health, without taking your engine apart.
Hope that helps.
  • MikeOK
Posted November 21, 2001 - 01:27 PM
100+ hours here, still stock and good compression. I think I'll try for one more season. I have some other mods to do this winter...
  • Shawbridge Husky
Posted November 21, 2001 - 01:57 PM
About top end : I am embarassed to say how many HOURS it took me to slip piston / rings into cylinder. Anyone out there have a trick for doing this easily? ( please no perverted comments ! ) :)
  • PK
Posted November 21, 2001 - 05:49 PM
I replaced my piston and rings in my 99 YZ400 because I had bought the bike used in 2000 from a guy who did alot hare scrambles so I wasn't sure what the motor was like on the inside. It ran great but to be on the safe side I tore into it. I was very surprised, the rings and piston were still in spec. You could still see the cross hatching in the cylinder, it would have gone another year. I replaced the piston and rings because I already had them and the motor was already torn apart. I also had to install a larger shim on one valve as it was getting close to the bottom end of the acceptable range. It took about an hour and a half longer to do my 400 as it does to do my wife's YZ125 top end. I would do a compression test before you tear into the bike, as was stated earlier, it is a good way to tell how the top end is doing.
Pat
  • Glen_T
Posted November 24, 2001 - 07:13 PM
Hey Hugh,
Lots of sweat, swearing or a big hammer! I'd like to know the trick too.
GLEN
  • Rusty
Posted November 25, 2001 - 04:53 AM
Hello, I'm new to the discussion forum. I have a 98 400 and I'd like to check my compression but don't have the specs. Can anyone tell me what kind of numbers I should be seeing.
Thanks
Rusty
P.S. Rusty isn't my name, it's my condition. Just getting back to riding after a 15 year layoff. Can't believe I stayed away from it this long.
Motocross
  • Hot  491 replies
  • Hot  28 replies
