Rear Brake weak
1 reply to this topic
  • counteru
Posted April 18, 2013 - 11:53 AM
I searched for several different things but none seem to pertain to my issue. So here goes!
I have a 2012 YZ450F and I took off the back tire today in order to swap out my old tire for my new tire.
After I finished getting the new tire on the rim, I put the tire back on and lined her up and checked my chain tension and all was good.
So, i crank her up and take her for a small test ride down the street to check and make sure everything felt ok. When I attempted to apply
the rear brake.... nothing! Normally, I can barely tap it and it nearly locks up. So, I press down harder and harder. I nearly have to put my weight on it
before it will lock up the rear.
What's happened? I didn't touch the brakes other than to move the caliper to the side in order to slide the wheel out. Anyone have a clue what I have done wrong or what's going on.
I checked the line to make sure no fluid was leaking just in case... and all is good.
I read a post where someone had a similar situation with weak rear brakes but his was after bleeding his brakes. I had no need to, and did not bleed nor brake the seal on the fluids period. So, why would it take soo much force to lock
up the rear now?
I am pretty sure I had no grease on the rotor because I made sure I wiped it off with a clean cotton rag before I put the wheel back on so surely I didn't compromise the pads by getting grease on them.
btw, the pads still look like new.
suggestions? cause im lost now!
  • counteru
Posted April 18, 2013 - 12:04 PM
umm, disreguard..... seems perhaps I must have gotten a lil soap on the darn pads somehow... after spraying with brake cleaner and letting dry it seems to be working better. Can delete! Thanks
  • Hot  28 replies
  • 5 replies
  • On January 15, 2017
  • Hot  38 replies
