replacement flywheel cover
2 replies to this topic
  • Paulreaper
Posted April 15, 2013 - 09:04 AM
Hi all. Ok recently cracked my crankcase cover on my 2004 wr450
Part number is 5tj-15411-10-00 so managed to find a breaker who
Has one off a 2003 model part number 5tj-15411-00-00. And he
Emailed me to say sdc-15tj00 is embossed on the inside of cover.
As I have done a temp repair dont fancy taking cover again incase
It totally breaks. So what im asking is what difference is there between
Cases as they look the same on microfische. Otherwise ill have to buy
A new one from states probably as cheaper over there then in uk.
Dealers here want £130.
Any advice much appreciated. Paul.
  • DeepPurplishBlue
Posted April 15, 2013 - 10:56 AM
The cover from the 2003 can be used, but you will find the hole for the shaft of the starter idler gear is too big.
You will need to install a bushing in order to use the 2003 cover with your 2004 starter clutch.
The yamaha part number of the bushing is [color=#282828][background=rgb(252, 252, 252)]90380-10002-00[/background][/color], it is not expensive, maybe $1.00
Edited by DeepPurplishBlue, April 15, 2013 - 11:00 AM.
  • Paulreaper
Posted April 15, 2013 - 09:09 PM
Hi thanks for the reply ive ordered one from the states now £103 all in.
