Anyone running the Rekluse EXP system?
32 replies to this topic
  • Mx Factory USA
Posted April 13, 2013 - 08:51 PM
Think I might run this set up in my bike to reduce arm fatigue clutching the piss out of my YZ 250. Any of you guys running this? What are your thoughts on this product???
  • Monk
Posted April 13, 2013 - 09:01 PM
Works great! Highly recommend them...
  • OZ DRZ
Posted April 13, 2013 - 09:08 PM
here's what i posted...
[color=#000000]REVIEWS & ISSUES WITH THE REKLUSE EXP AUTO-CLUTCH[/color]
  • Mx Factory USA
Posted April 13, 2013 - 09:36 PM
Oz Drz thanks for the link. After reading that I think this system will not suit my needs. I really would like to still use my clutch for holeshots as I will be using this to race on mx tracks...
  • Monk
Posted April 13, 2013 - 09:52 PM
I don't really agree with any of this....
  • Mx Factory USA
Posted April 13, 2013 - 09:55 PM
What's your rebuttals on this review??
  • tim512
Posted April 14, 2013 - 05:15 AM
There is heaps and heap and heaps of threads on this already which you can search for.
However, I think the Core EXP is the one that allows you to continue to use your clutch like you're used to but also get a bike that is impossible to stall...
  • Chill_MotoX
Posted April 14, 2013 - 06:42 AM
I have the core exp, also just installed a hydrolic jack clutch for that extra overkill... Absolutely love this set up
  • souliog
Posted April 14, 2013 - 07:06 AM
Try working on technique....after riding 450 thumpers for the past 8 years, I can say you shouldn't need that much clutch on a yz250. I started riding a two stroke last year and was amazed how little clutch I need to use on my yz250 as compared to my yz450f
  • Mx Factory USA
Posted April 14, 2013 - 08:51 AM
I read you can still use the clutch on this but it's a stiffer pull. Now I understand how you set it up and exactly how it works. I probably should have read the 5 million other threads before I posted a new one. I think I will like this set up, I'll buy it and try it out. If I don't like it I can allways send it back!
  • Mx Factory USA
Posted April 14, 2013 - 10:32 AM
You use the clutch less on 250 2 smoker than on a 450? What world do you live in?
Edited by MXpro787, April 14, 2013 - 10:32 AM.
  • souliog
Posted April 14, 2013 - 10:55 AM
I've been really working at riding the 250 more like a thumper so I don't get as tired.
  • Mx Factory USA
Posted April 14, 2013 - 11:40 AM
I agree I been on 4 strokes since 2005. I have a 450 now and a 250 2 stroke. A flywheel weight helped a lot with reducing fatigue on the smoker but still have to finess the clutch a lot to keep momentum up around corners on mx tracks. That gives me major arm pump during long motos. I think the rekluse will help a ton.
  • kingkabong
Posted April 14, 2013 - 11:46 AM
I'd go z-Start Pro or CORE EXP. Search around.
  • J_YZ2fittyF
Posted April 14, 2013 - 11:53 AM
My rebuttal on this...
If you stall on a steep hill, you don't have the clutch there to hold the bike still. This can be a big issue if you can't hold the rear brake on.
Shouldnt stall on a steep hill, if his "good" holds true...
The bike won't stall and even if you drop it it will normally run until you pick it up.
If it is set up properly, and your BIKE is set up properly, it should in theory never stall. Therefore stalling on a hill shouldnt ever be a problem in the first place. But if your bike is jetted poorly, or otherwise stalls due to faults in the motor itself, then the rekluse cant help that.
I dont have an exp, i have a zstart pro. And I will say that should it stall, its probably a bad set up on my part, or as i am having an issue right now with weird bog on my low end which is causing my bike to cut out entirely...not a low rpm stall the rekluse didnt catch. But you can't bump start the zstart, i dont know much else about the exp. I also know I can still use my clutch with the zstart (ie on a start), it just feels different (pull wise).
  • souliog
Posted April 14, 2013 - 12:05 PM
Ok...how will the recluse help? It doesn't have an auto-finess function. Haha.
I had to go back to the old school 2- finger clutch technique and try to reduce using it overall. Line choice and rolling the throttle on helps save energy.
I am going to try the heavy gytr flywheel next.
  • Mx Factory USA
Posted April 14, 2013 - 01:09 PM
Rekluse will allow cornering at a higher gear less clutch finess and no stalling. $400 upgrade to keep me competitive against these younger kids in the 250A class sounds like a win win situation to me.
The flywheel weight helps a ton but the heavier ones rob top end pull. I recommend installing one that's less than 9oz if ur riding mx tracks...
  • souliog
Posted April 14, 2013 - 01:49 PM
Thanks...I'm going to try the 8 oz fw.
Let us know how it works out for mx. Good luck against the kids.
  • souliog
Posted April 14, 2013 - 02:33 PM
Ok...so I did not know much about these rekluse clutches.after watching some vids, I want to try one too. What' the difference between the three.
Edited by souliog, April 14, 2013 - 02:33 PM.
  • Mx Factory USA
Posted April 14, 2013 - 03:13 PM
Well the z start is the best set up they have but the $800+ price tag is more than I would like to spend. But this system is extremely durable and has a lighter clutch pull. Install and set up on this can be tricky as it needs to be gapped perfectly. The bearings sit in grooves and are more shallow on the outside of the plate, so when the assembly spins the bearings are pressed outward and that presses the clutch plates together engaging the clutch.
The EXP installs in your stock clutch basket. It costs around $400. Down fall with this set up is if your creeping around letting the clutch slip a lot at low speeds it will wear out your clutch plates quick and it has a tighter clutch pull. They both work in a similar fashion but are way different. With the exp you don't run freeplay you keep the pressure plate pushed out, when you hit a higher rpm the wedges transition and expand the clutch pack to the pressure plate engaging the clutch assembly...
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
Squish or #8 slide? by yz dude
  • Hot  27 replies
What would you buy? by 2000YZ250
  • Hot  45 replies
3 points of Spooge by CaptainKnobby
  • Hot  60 replies
what bike? KTM,RM,YZ,KX,or CR 125 by Numsa Hul
  • 8 replies
