New jetting with UNI filter?
2 replies to this topic
  • slowxr
Posted December 03, 2003 - 01:52 PM
Bike is uncorked and running good.
All things being equal, if I remove the stock airfilter and replace it with a UNI will I need to go up in jetting? And if so, just the main?
  • qadsan
Posted December 03, 2003 - 03:43 PM
Probably not. It really kind of depends on your current jetting and your riding location (altitude & temperature). If your bike is already running a bit lean, then you'd probably want to fatten it up a bit (maybe go up 1 size on the main), but most bikes I've seen are already running plenty rich and the addition of a Uni Filter usually doesn't require any changes. Don't chuck your stock filter cause it's a good filter and comes in handy as a spare :)
What kind of jetting specs do you currently have? Is your side panel cut out? What kind of exhaust do you have? What altitude and temperature are you mostly riding at?
  • slowxr
Posted December 04, 2003 - 09:35 AM
I just did the recommended uncorking mod's as far as jetting goes. I drilled out the stock muffler tip with a 2 inch hole saw. Other then that, it's stock. I usually ride between 4-6K feet w/air temp 50-70 degrees.
Honda XR650L 2016
  • 0 reviews
  • Hot  35 replies
  • 17 replies
  • 4 replies
  • 22 replies
