2000 YZ426 Leak Jet Question
2 replies to this topic
  • mn_biker
Posted April 04, 2013 - 08:18 PM
Hi everyone,
So, I hate to bring this up since it appears that it has been beaten to death but I am having an issue with my bike.
I am having a hard time finding my leak jet on/in my carb. I've read everything I can find on locating it and I cannot find to save my life. I took a picture of the float bowl so maybe one of you can help me out.
The reason I am trying to find it is to do the DOC mod because I did the BK mod earlier tonight.
Posted April 04, 2013 - 09:31 PM
You're having trouble with that because there isn't one. The first YZ4xxF with a leak jet was the '05 450.
If it had one, it would be in the dimple you see at the bottom of the bowl, at 7:00 o'clock to the center jet well plug in your picture, directly above the hole at the bottom of the picture, directly right of the hole on the left edge.
  • mn_biker
Posted April 05, 2013 - 10:50 AM
OK. So no leak jet means no need to do the DOC mod then? I'm guessing since I don't have one the AP is always at full? My bike was a bear to cold start before I dug into it and found the valves were too tight. So I'm trying to get the carb all setup before I put it back on the bike.
If I'm correct I'll just replace the MJ, PJ, and needle with my new FMF ones and install the new AF screw too. Although I do think I need to replace my AP diaphragm because I found a small tear in it.
Of course I'll still have to set the AP timing and length.
  • Hot  50 replies
  • 0 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
