09 yz 450 clutch?
1 reply to this topic
  • Fox450F
Posted April 03, 2013 - 02:45 PM
Was Wondering if anyone can help. When i gear down in the lower gears i downshift into lets say first. i let the clutch out and the bike is idling alittle bit higher than it should I have to then pull in the clutch in and then let out a hair for the bike to idle down. Maybe carb adjustment or clutch?? Any help would be great
Posted April 04, 2013 - 07:24 AM
Idle's too lean. maybe leaking air, hot start cable snagged or misadjusted, or even a tight intake valve, but may be simply that the fuel screw needs adjusting. Bump it out a half turn.
  • Hot  79 replies
  • 0 replies
  • Hot  33 replies
