twitchy front end
2 replies to this topic
  • iron_savior
Posted December 02, 2003 - 12:47 AM
hi there,
anyone know what would cause my front end of my xr650r
to feel twitchy
and what riding conditions would suit having your rebound
on the hardest or softest setting, i'm battling to set up my bike correctly.
thanks you
w :)
  • cat0020
Posted December 02, 2003 - 06:12 AM
-Any dents in the rim?
-bulging in the front tire, front tire is not balanced??
-worn headset bearing?
All those could be suspects.
  • qadsan
Posted December 02, 2003 - 07:52 AM
In case the items above don't resolve your twitchy front end, here's some less likely things to check for.
- Loose steering stem nut (torque it to spec)
- Front wheel not true (check roundness and side to side runout / tighten spokes)
- Not enough rear sag (check static & race sag)
- Fork tubes sitting too high in the clamps (raising the fork tubes in the clamps makes steering quicker, but sacrafices high speed stability)
- Suspension fluid (your fork oil may be worn out)
- Tire Choice (some brands & compounds of tires work better than others, so make sure to use something that's known to work well for the type of terrain you're riding on)
Honda XR650L 2016
  • 0 reviews
  • 4 replies
  • 9 replies
  • 22 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
