Yz450f Carburated - Regular maintenance tips
9 replies to this topic
  • Kennethyz450f
Posted March 31, 2013 - 04:12 PM
Just Bought an 06yz450f with 10 total hours on it had ben sitting for a long time but the guy started it up every month and its runs great, has fresh oil and filter and aircleaner. I just wanted to get some advice on some general Maintenance on this bike, I ride trails only and im not to hardcore and dont rev very high.. Thanks!
Edited by Kennethyz450f, March 31, 2013 - 04:13 PM.
  • Fade
Posted March 31, 2013 - 05:57 PM
Valve checks every 15 hours. Oil and filter change every 15 hours. Tire pressure every ride. Chain tension every ride. Air filter every 1-2 rides.
That's pretty much it other than keep it clean for "simple maintenance"
Check the brake pads alot, would suck to ruin a rotor. Sprocket wear. Chain guide wear.
Can't think of much else
  • 559stan
Posted April 01, 2013 - 04:21 AM
I have a 07yz450. Check the steering head bearings for grease. Get an easy to adjust by hand pilot screw for the carb.
  • FinchFan194
Posted April 01, 2013 - 09:32 AM
Oil every 15 hours??? More like 5.
  • Fade
Posted April 01, 2013 - 11:34 AM
If you're riding it super hard, then yes. For light riding, 15 should be okay.
  • slothman
Posted April 01, 2013 - 01:32 PM
the key to not gumming up the carbs is to run the bowls dry before storing for a few weeks/months. Just turn the gas off and let the bike idle, it will burn all the gas in the carbs. Also leave very little gas in the tank when storing it, or just drain the entire tank. I like to use a fuel stabilizer before storing.
If it has fresh oil and new air filter, you should change the spark plug. Also check the valve clearance.
  • FinchFan194
Posted April 01, 2013 - 03:18 PM
The oil will break down at the same rate regardless of how hard it is ridden.
  • f150jokerstyle
Posted April 01, 2013 - 05:12 PM
I disagree the harder you ride or a better way of putting it the more heat generated the faster oil's break down, then there is also the aspect of clutch abuse which can send a lot more contaminates into the oil than merely the oil it's self breaking down. I spend extended times close to and at wide open and under heavy loads on my bike doing desert racing in the usual 80+ miles I ride at a time I encounter miles of sand,, rock and hills. Some times after a race I have boiled about a quarter of my coolant out in slow going rock areas and ruin a clutch in one race. After just one 4 hour race in those conditions the oil and filter is toast(I use paper and change regularly). Now take another 80+ mile ride with some buddies with a packed lunch I can get 2 of them in and the oil still is in as good as shape as what I stated above and it will actually have more hours on it. That is my 2 cents and NO I have not sent in samples to verify but the old eye and touch test does not lie in my opinion. That being said I would not go 15 but I sure would go 8 but that is mainly due to my access to oil. If I were buying at full price I surly would stretch it out longer in some cases.
  • FinchFan194
Posted April 01, 2013 - 05:34 PM
I agree, 15 is clearly WAYYY too long though.
  • DrNation86
Posted April 02, 2013 - 11:56 AM
Wheel Bearings
Swing Arm Bearings
Rear Shock Bearings
Steering Head Bearings
Muffler Bearings haha j/k on that one
Making sure those arent wore out or are greased can free up some power and control.
  • Hot  113 replies
  • 10 replies
  • Hot  50 replies
  • Hot  30 replies
