Lean angle sensor 2012 wr
5 replies to this topic
  • BMWbeej
Posted March 30, 2013 - 08:49 PM
So I read in the manual somewhere the bike has a sensor when dropped the ignition switch has to be reset...
Is there a way to disable this as I can see it being a slow pain in the arse if you drop the bike in a "special test" when your
getting timed to the second!
Cheers Beej.
  • JDLowrance
Posted March 30, 2013 - 08:55 PM
It's located under the tank on a thin steel bracket.
It basically will shut off motor after a set amount of time (not sure how long) of being imobile nad on it's side. Basically all that is required is cycling the on/off switch and it'll fire right up.
Not sure about disabling it.
  • Lumberjack450
Posted April 09, 2013 - 09:08 PM
I have never run in to this turning on in almost 100 hrs and many crashes and drops..
  • Krannie McKranface
Posted April 10, 2013 - 04:28 AM
60 seconds past 60 degrees
  • GP1K
Posted April 10, 2013 - 07:52 AM
Yeah not sure why you'd want to disable this, not like it shuts off the moment the bike falls over.
  • BMWbeej
Posted April 11, 2013 - 09:48 PM
Thanks for the replys ! If it takes that long to cut out i'm not worried then... Obviously the last time I dropped it on a hill it must of stalled
and not "cut out" as it was only down for about 10 seconds.
