Tips for starting a bike after 2 years sitting?
3 replies to this topic
  • Mattymo83
Posted March 30, 2013 - 01:07 AM
I have an [color=#ff0000]02 YZ426F[/color] about a year and a half ago I started loosing the clutch in a race, so I put it away. now I've put a new clutch in about 5 months ago, after a year of sitting, I managed to start it for about 2 mins and it stalled and would not start, I am going back to get it ready this weekend and I need tips. The carb was factory rebuilt just before the clutch went. I added fuel stabilizer before it was put away.
What I'm giong to do is:
-Drain the fuel tank and add fresh fuel.
-pull clean and gap the spark plug.
-clean and oil filter.
What I need to Know is:
-Any thing else I should check?
-When should I shim the valves?
and most importantly
-I found a small amount of metal in the oil after the clutch change, I flushed 10L through till there was no more, but could those be from the clutch, or should I rip the engine apart now and rebuild it before I try to start it.?
It ran like a top in the last race untill the clutch started going, first kick, hot/cold, like a top, piston and valves only have about 10 hours of use, I need solid advice on my next action.
Thanks -Matt Moran
  • yz133rider
Posted March 30, 2013 - 01:16 AM
Pull the carb, clean out all the jets with carb spray and compressed air replace the small jets and reassemble carefully.
  • GuyGraham
Posted March 30, 2013 - 01:24 AM
blocked pilot jet
replace it and go from there
  • Krannie McKranface
Posted March 30, 2013 - 05:41 AM
Dont use carb cleaner, it will melt the internal rubber parts. Use brake cleaner or simple green
