fork oil weight
Hello I 'm a new07 WR450 owner, I have been trying to find out what weight the oil is for the forks? I know it is Yamaha S1 but even the people at a local Yamaha store here don't know if its 1, 3, 5 or what weight it is. I tried to do a search and like I said I'm new but have not had any luck with the stock S1 oil weight any insight would be greatly appreciated. Thank you
Use 5wt.
its actually closer to 2.5 weight, with a reported viscosity of 15.6 centi-stokes, but 2.5w fork oil is very thin which is great for fade resistance but provides little in the way of lubrication - see chart below
As you can see, one make of 2.5 wt is not the same as another make of 2.5 - choose a brand and stick with it - I have had good results with Motul Factory Line Fork oil, but even there Factory line oil differs from their ordinary oil in terms of viscosity so beware
PJ1 Fork Tuner 2.5w is 26.1 centistokes yet Castrol Fork oil 10Wt is thinner at 15 centistokes, which is the same as most other 2.5W oils!
Go with 5W
You will soon find that the forks are somewhat lacking in performance, bring harsh over small roots, yet blowing through the stroke and bottoming out really easy
This is due to the unique (rubbish) design of base valve in the fork
Have a read of this - http://www.thumperta...50-fork-valves/
I also suffered from a lack of rebound damping in my forks of my 08 model - it needed 10W oil to get anything resembling some damping in the rebound which just made the slow speed compression problem worse
When I opened up my forks to put gold valves in, I found the nut loose on the rebound stack, inside the cartridge, which was just letting the shims lift and the oil flow by without providing any damping
You may also find the fork springs to be soft, depending upon your riding style and weight
They are quoted as being 0.46kg/mm, but mine actually measured 0.41kg/mm, which came as no surprise to my suspension shop - he said WR's are notorious for underrated springs in the forks as they come from Yamaha
I put in some proper 0.44kg/mm springs and it transformed the bike (along with the gold valves), but then went to 0.46kg as my riding speed improved and I was working the bike harder
The stronger 0.46kg/mm springs overwhelmed the the stock rebound damping, so I had to increase the rebound shim stack strength from 6 x 0.1 face shims to 1 x 0.2 & 2 x 0.1, which gave me just abit more damping on the min setting to what I had on the max setting previously
Edited by GuyGraham
Thanks - GuyGraham - good advice on oil and spring rates for the strange suspension on the WR --- how can the YZ be so good and the WR so .... so-so.
