2007 - 2011 Fork Shock Spring Rate - What are you running
4 replies to this topic
  • TX-SANDMAN
Posted March 29, 2013 - 11:09 AM
I now have a "new to me" 2009 WR450F - just plated it - what a relief.
Now on to the marshmellow suspension. I know they need a revalve, but i was wondering what spring rates you all where using. Spring Rate / Rider weight?
  • Krannie McKranface
Posted March 29, 2013 - 12:06 PM
Race tech dot com.
Spring rate calculator
  • TX-SANDMAN
Posted March 30, 2013 - 07:14 AM
Paul Thede's calculator says I should use stock springs --- I am about 165 lbs. I was just wondering since the springs feel so soft what other folks are using.
  • GuyGraham
Posted March 30, 2013 - 11:01 AM
205lbs and i run 0.46kg/mm forks springs and 6.0kg/mm in the rear
I've got 25/100 sag figures on the rear
  • upnorthbacon
Posted March 30, 2013 - 12:38 PM
I'm 210 and running 5.8 and .48 and it works well. The valving is definately too soft for anything fast or any type of air, but works great in tight gnarly stuff.
