What type of ball hone do I need?
12 replies to this topic
  • ttr250dude
Posted March 25, 2013 - 05:55 PM
It's an '08 450f. What type of ball hone do I need?
  • davek18
Posted March 25, 2013 - 06:21 PM
none at all.
  • ttr250dude
Posted March 25, 2013 - 07:51 PM
Why not? Can anyone else chime in? I've never heard of a cylinder that doesn't need cross hatching with a new top end.
  • davek18
Posted March 26, 2013 - 04:05 AM
They really don't need it, and you introduce more filings and rough edges for no reason doing so. Don't hone, dry assemble and it will run better than ever. Done it hundreds of times on cars, bikes, industrial engines, you name it.
  • luvnoldcars
Posted March 26, 2013 - 04:21 AM
This is what I use. http://www.enginehones.com/niapho.html
Posted March 26, 2013 - 06:44 AM
Brush Research makes the best ones (the page linked above is selling BR "Flex Hones"). Use an aluminum oxide hone. The hone needs to be slightly larger than the desired bore size, but BR hones are sized according to the bore they will finish, so the right size for yours is the 3 3/4" (95mm) unit.
  • ttr250dude
Posted March 26, 2013 - 03:17 PM
For $43 I'll just use the ones here at school.
  • ttr250dude
Posted March 27, 2013 - 11:15 AM
Would there be any harm if I use the wrong type of ball hone?
Posted March 27, 2013 - 11:29 AM
Yes. If you use too hard an abrasive, too large a hone, or too coarse a grit, you may damage the Nikasil plating. If you can spend $43 on the right hone, just skip the whole thing and clean it up with Scotch Brite and hope for the best.
  • hackman162
Posted March 31, 2013 - 01:58 PM
Gray, I've always used emory cloth on the cylinders, but of course that is when there is still cross-hatch visible. Whats your opinion on that?
  • ttr250dude
Posted April 01, 2013 - 03:33 PM
What grit should I use?
  • davek18
Posted April 01, 2013 - 05:52 PM
Scotch brite
Posted April 02, 2013 - 06:15 AM
Aluminum oxide, 320 grit. Read the post linked in my original response.
  • 0 replies
  • Hot  491 replies
  • Hot  28 replies
Help with 2000 yz426 by weekend woods racer
  • Hot  36 replies
