426 cooling issue
7 replies to this topic
  • 1st_yzf426_myfoothurts
Posted March 25, 2013 - 04:43 AM
Purchased the bike not long ago and when it gets warmed up the coolant starts coming out of the breather hose. And makes a puddle under the bike I have only let the bike run long enough to make a small puddle cause I'm not sure if I have a bigger problem at work here any help would be awesome.
  • marv02
Posted March 25, 2013 - 05:10 AM
This bike needs to be moving it don't like to stand still and idling for a long time if you top off the coolant it going to spit some out when cool if you take off the radiator cap seeing the top of the cooling fins is normal.
These bikes were never made to be sitting still when running if you want a bike that you can sit still while running should got an air cooled XR even those you should not sit still too long.
The air while the bike is moving cools the motor.
Posted March 25, 2013 - 07:00 AM
The coolant level is pretty high I do know that. But it will do that in a matter of two minutes of running? And I have heard that engine I've can help with that?
  • jojo1224
Posted March 25, 2013 - 07:41 AM
2 Minutes idling is way to long. Fire it up and keep checking the temperature of the rads, when they get warm your good to go.
Posted March 25, 2013 - 07:43 AM
So basically get moving pretty quick laugh out loud got it.
  • jojo1224
Posted March 25, 2013 - 10:10 AM
Exactly :thumbsup:
Posted March 25, 2013 - 10:26 AM
Thanks a lot man
  • YamahaFan81
Posted March 26, 2013 - 05:59 AM
I put a boyesen super cooler in, fluidyne radiators and I put engine ice in to. Now she runs a lot cooler than she did.
  • Hot  50 replies
  • 9 replies
  • Hot  47 replies
  • Hot  36 replies
