For those of you who are considering a new carburetor, or what your next carb mod will be, I thought I’d pass on my experience so you may learn from it. It's a little long, but I wanted everyone to have the whole history so you can make your own conclusions.
I bought a DRZ-400S last December. I hadn't been riding for many years, and I would consider myself a novice compared to most of you. My skill level is enjoying jeep roads, fire roads and single track up to intermediate level. I can do some of the advanced trails, but I really don't enjoy those trails (yet).
I live at sea level. When I first got my bike I didn't notice anything wrong with it being totally stock. As I started to get the feel for the bike I started noticing slow throttle response and some hiccups after hitting the ground a little hard. Other than that, it ran really well at sea level. When I really started to notice issues was when I would go ride in the local mountains. First rides were around 3500-4000' and I had serious carburetion problems, hesitations, lack of power, etc.
So I read all of the recommendations on Matt Nelson's page (http://drz.info) and burned's faq. I started making what I felt were very simple steps towards improvement. First thing I did was the air box mod and jetting recommendations with the Dynojet kit. Noticeable improvement in power at sea level, but still has a slight (annoying) hesitation. My next ride was at 4000-6000' and the bike ran "ok" at 4000', but like crap above 4500'. Next trip was going to be at 7000-9000' for 4 days, so I got recommendations here (thank you Burned) before I left. Got up there and the bike only ran "ok". It would stumble from idle and low RPM, and it always seemed to be right when you needed throttle. However, thanks to Burned’s recommendation, my bike was at least rideable. My friend’s DRZ (with a Dynojet, and a 25 pilot jet being the only mods) had a terrible time. The bike was running so bad it almost didn’t run at all, and often cut out.
So now I'm almost configured for 7000-9000', but am back home at sea level again. I still don't have it right for sea level (home), local mountains (3500-4000 down to sea level) OR higher-elevations. By this time I've had the carb on and off 4 times. Each ride was a disappointment because the bike hasn't been running right.
So, I start thinking of the E model (Keihin) carburetor. When I added up all of the parts I saw it was going to be quite a big project both $ and time. Once I started to research the jetting for THIS carb I found it too has recommendations for jetting for various altitudes. Sigh.
I knew that going from a CV carb to a slide-carb w/accelerator pump would be an improvement, but I'm still going to be taking the thing apart and re-jetting for these various rides. I was pretty disappointed at the prospect of having to do carb adjustments forever or start skipping rides with my friends because of the elevation changes. I thought it sure would be nice to have an externally adjustable carb.
Then one of my friends told me about the Edelbrock carb. I started researching it and found people who hated it and people who loved it. Then I began to notice that people who said it was junk didn't mention ANY specific reason. So I did some more research and found that it WAS junk ON A PARTICULAR KTM where it was used. I also read that KTM had configured the carb against Edelbrock's recommendation. I also learned that the carb with the bad reputation was nothing like the currently available Edelbrock carbs. Having done quite a bit of business with Edelbrock in the automotive industry, and knowing a bit about the company and their history, I considered trying it.
I sent an e-mail to Edelbrock and they referred me to Rob Barnum. I called and talked to Rob for about 15 minutes and told him what I had done to my motorcycle to this point and what I wanted. He told me of the history of the carb, and what he had done with Edelbrock, and that he wholeheartedly recommended I try it. I re-iterated my want to be able to change altitudes without tearing the carb apart and he told me it had 30-clicks of external adjustment, and that it should suit all of the altitudes where I planned to ride. He said I would be pleasantly surprised and offered to help me dial it in if I had any problems. I debated it for a week or so, and then plopped down about $500 for the carb and the parts I needed from Suzuki.
AM I EVER GLAD I DID!
The kit that comes from Edelbrock contains everything you need except the "intake pipe" and 1 clamp that you need to get from Suzuki. ($20) New Motion Pro throttle and cables are also included with the kit. The instructions were very good, lots of detail.
I put the carb on in its out-of-the-box configuration. The whole job took about 3 hours, then I rode my bike at sea level. It was amazing. It started right up, faster than it ever did with the stock carb. Instant throttle response, smooth power no matter how fast I rolled it on, and noticeably more powerful than the best configuration I ever obtained with the stock carb, even after all the modifications. This was with no adjustment!
I knew the first test would be going to altitude so last week I took a ride into the local mountains. I made this ride the same ride I had done in the past. I started at 3800' and went down to about 200'. At 3800' I could tell the bike was running a little richer than at home, BUT, no hesitations, no stumbles, no lack of power. Just to try the externally adjustable feature, I leaned it out three clicks and it ran absolutely great. When I got down to 200' I never changed a thing, it ran better than it did when I first installed it (probably was a little rich then, too). I could have ridden it without ANY changes, but I was able to make it perfect with a twist of a knob.
I realized I was on to something when I finished the ride and made a slip of the tongue to my friend, I said "On my old bike that would have been a [@#$%&!]." This WAS my old bike, but it seemed like a whole new ride and I never once had to "think" about throttle.
So, in summary, I have a DRZ-400S, with a 3x3 air box, stock exhaust, Edelbrock Performer 3118 carb and have more power and INSTANT throttle response than with the stock or modified stock carb.
I know there WERE problems in the past with a particular model Edelbrock carb on a particular bike, but this is a different carb and a different bike, and it made a dramatic positive improvement on my DRZ. If any of you are in the San Diego area and would like to test it for yourself, drop me an e-mail and we’ll get together. I think you’ll be impressed.
I have no connections with Edelbrock or Rob Barnum other than now I’m a completely satisfied customer.
scotto
