Smog block off question
8 replies to this topic
  • rnrdozer
Posted November 30, 2003 - 08:56 PM
I have a 00' 650R and wanted to take the smog crap off it, can I just remove the smog unit that bolts to the right radiator and loop the two tubes going into the head together? or is there some reason for that unit. I noticed a vent hose ran all the way to the air cleaner. Thanks in advance.
  • Eric_Mc
Posted December 01, 2003 - 02:15 PM
My 02 650r runs better without that stuff on it! I used the kit from Applied Racing which I purchased through TT. I removed all that tubing and you have to put a few plug/ caps on here and there. The hardest part is removing the two metal tubes that come out the front of the head! Mine was a Royal pain to get out! The rest was a snap! You will probably be hearing from the pros for there advice, they are awesome help! :) Good Luck!
  • BWB63
Posted December 01, 2003 - 03:50 PM
Eric, Your a pro now tell him how you did it! :)
  • Eric_Mc
Posted December 01, 2003 - 07:31 PM
Not quite! But thanks for your confidence. If he wants me to tell him, I will. I just have to figure out a way to tell him without all the cursing I used! It kinda went like this! :) :D :D :D :D :D :D :D :D :D
  • BWB63
Posted December 01, 2003 - 10:23 PM
You are a funny guy! Great humor. Isn't the thread with all this still going? It's got the whole mess! :D I looked new month it's gone :)
  • fourstrokin650
Posted December 04, 2003 - 09:54 PM
On my 650, I pulled it all off and then cut the two tubes off of the plate that bolts to the head. I then welded the holes shut and bolted it back on (don't loose the orings). Free block-off kit! I also used an allen wrench that I cut down until it fit into that super tight area. That makes it easier as well.
  • Eric_Mc
Posted December 05, 2003 - 07:43 AM
:jawdrop:I too tried the shortened allen wrench trick. I broke two wrenches before having to get a long screwdriver and a hammer to knock the %#@& thing loose! I think they (Honda) torqued mine to about 100lbs? It was a real pain! :D But it is all good now! :)
  • big t
Posted December 05, 2003 - 08:25 AM
Do all the 650's have the smog stuff or is it just the CA models?
  • qadsan
Posted December 05, 2003 - 08:44 AM
Just California models are blessed with the PAIRS smog system. CA is special :)
  • Hot  35 replies
  • 3 replies
  • Hot  29 replies
  • Hot  186 replies
