Boots rubbing paint off frame
13 replies to this topic
  • D-rek07
Posted March 17, 2013 - 04:49 PM
Obviously this is only for '06 and earlier but I need help. I have a 2006 WR450F. My boots are rubbing the paint off the outsides of the frame. As of right now, I put gorilla tape over it to stop this but it looks kind of dumb. Has anyone else had this problem and did you anything to fix it? Thank you.
Edited by D-rek07, March 17, 2013 - 04:49 PM.
  • samras121
Posted March 17, 2013 - 05:34 PM
dont worry about it and ride? its going to happen.
  • Krannie McKranface
Posted March 17, 2013 - 05:57 PM
Is the issue that you don't want to see any wear marks on your frame?
If so, you can purchase 'frame guards' from several manf, like Litespeed, works performance, etc.
I just threw away my frame guards for my '03 cause I could not even give them away on Ebay......
  • D-rek07
Posted March 17, 2013 - 07:25 PM
I don't want the paint to be worn off. I have the frame guards but I mean on the part above the frame guards. I have seen some pictures of these models that are still covered by paint.
Edited by D-rek07, March 17, 2013 - 07:26 PM.
  • Thommo_400f
Posted March 17, 2013 - 07:30 PM
Take your boots off :lol:
  • MANIAC998
Posted March 18, 2013 - 04:41 AM
It's a dirtbike! It's not a Museum Showpiece. While I concern myself with a good looking bike, trying to keep the frame paint from rubbing off is very, very low on my list of importance.
  • D-rek07
Posted March 18, 2013 - 07:32 AM
I'm not so concerned with what it looks like, but I don't want the bare metal to rust. Some of it has already rusted. Right now, after I wash it, I have been putting WD40 on all the bare metal parts. I don't really want to keep doing this.
  • LucasLeader
Posted March 18, 2013 - 11:14 AM
It looks like UFO used to make some big plastic frame gaurds that went much higher up on the frame than most others. Some people use rubber from an old innertube wrapped and zip tied onto the frame.
  • n16ht5
Posted March 18, 2013 - 12:55 PM
If her boots rub the paint off then they aughta rub the rust off too. Real bikes look tough like they been beat with a hammer anyway
Posted March 18, 2013 - 02:26 PM
It's Cro-moly steel, so it will only rust superficially.
Oh, and every single one of us here have the same problem.......it's solved by DRYING OFF YOUR BIKE after you wash it.
  • MANIAC998
Posted March 18, 2013 - 02:45 PM
Like Lucas said, UFO use to make some frame protectors, and still might. While the right side mounts right up, the left side needs some trimming to make it fit well. This is what I did to my '06. Just be aware that while your boots will no longer rub the frame paint off, the frame guards will instead. You won't be able to see it, but it's still happening. Like Krannie said, it's only superficial anyhow.
  • D-rek07
Posted March 18, 2013 - 05:28 PM
Off course I dry it off. It had some rust on it when I bought it.
Edited by D-rek07, March 18, 2013 - 05:32 PM.
  • Just_a_trail_rider
Posted March 18, 2013 - 10:23 PM
Here is a picture of my 05 before I sold it like a damn fool! :cry:
See above those frame guards??? What you see there is a piece of hose I got from home depot. If I remember correctly, its the hose that goes to a dishwasher or a garbage disposal. I cut it and zip tied it to the frame. Paint doesn't run off anymore. Any piece of black hose will do.
Edited by mauricedorris, March 18, 2013 - 10:25 PM.
  • slippyfoot
Posted March 19, 2013 - 06:09 AM
if you have intact paint or decide to repaint it, you can cover it with the clear plastic adhesive film they use for headlight covers. You can buy it as bulk film. You'll probably need to get it to wrap most of the way around the frame tube so it doesn't peel up from the edge.
http://www.invisible...om/bulkfilm.htm
I've also painted a street bike in this area with rattle can truck bed liner. It held up fine to easy street riding but not sure how it would do with mud and mx boots.
-Mike
