I have a Yamazuki where do I fit ?
1 reply to this topic
  • xxcody2gunsxx
Posted March 16, 2013 - 09:21 PM
I have a 2012 Suzuki drz400s with 2008 Yamaha YZ450 Forks and triple clamps .
I am having a little bit of binding when turning it to the right side . wonder if its the races or not .
the races are from the original DRZ400S . the 2008 dont seem to fit .
also wondering what the torque is for the stem nut . maybe I have that too tight .
I also have a 39mm FCR 39mm MX carb from the 2008 YZ and I want to install . any help there?
Posted March 17, 2013 - 08:28 PM
The YZ stem sets up this way:
  • With the bearings cleaned and lubed, run the ring nut down to around 25 ft/lb and rotate the bottom clamp side to side a few times.
  • Loosen the ring nut about a full turn, then retighten to 6-7 ft/lb
  • Install the top clamp and tighten the crown nut to 105 ft/lb
What I don't know is whether the dimensions of the DRZ races match up with the YZ bearing assemblies well enough to work right or not.
  • Hot  79 replies
  • Hot  33 replies
Need help by Goforaride
  • Hot  68 replies
  • 0 replies
