EZ starting
1 reply to this topic
  • rwcfrank
Posted November 13, 2001 - 05:58 AM
I am new to TT and was wondering if ayone had thoughts regarding my starting technique.. I always get my 426 to start on the first or second kick cold or hot (with choke cold and sometimes with the hot start when its hot) my question is this, I crack the decompression lever just far enough to open the valves, I kick her thru and release the compression lever just as the kicker nears the end of the stroke. The inertia and speed of the lever stroke starts her anytime. Do you think the valves will ever contact the piston??? I dont think its happening now and it makes her real easy to start... Thanks..
01 WR426
air box mods
e series pipe
grey wire
throttle stop mod
Acerbis bark busters
YZ rear fender
and looking for anything to remove for weight reduction..
  • john.hilton@cape.k12.de.u
Posted November 13, 2001 - 06:48 AM
Frank, I can't speak for anyone else, but I wouldn't start my bike that way.
Here's what I do, which also works like a charm every time.
IF THE BIKE IS COLD: Choke on, two quick blips of gas, kick slowly till the kick starter won't move down any more. Pull in the decompression lever and push the kick starter down about an inch. Let the decompression lever out, bring the kick starter up to the top and give it a good boot. This is actually a lot easier than it sounds.
IF THE BIKE IS HOT: Same except NO blips of gas and no choke. If it doesn't start on the first kick, I pull the (Red) hot start button and repeat.
It has ALWAYS started in no more than 2 or 3 kicks.
Need help by Goforaride
  • Hot  68 replies
  • Hot  36 replies
  • Hot  491 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
  • Hot  28 replies
