bike dies when throttle turns please please help!
Posted 10 March 2013 - 02:16 PM
Posted 10 March 2013 - 05:49 PM
Probably a lump of crap blocking main jet.
Posted 10 March 2013 - 08:10 PM
Posted 10 March 2013 - 09:05 PM
13+, on 10 March 2013 - 08:10 PM, said:
No, stop guessing.
You need to do more trouble shooting first.
1. is the gas getting into the carb
2. is the gas getting into the intake
3. is there spark
4. is there compression
Posted 10 March 2013 - 09:16 PM
Krannie, on 10 March 2013 - 09:05 PM, said:
No, stop guessing.
3. is there spark
Okay so i havent tryed anything yet, but now that I think about it the bike will only run for a few seconds when its in the on position but when its on reseve it runs just fine. But I will do those tomarrow.
Posted 11 March 2013 - 04:54 AM
While Krannie is right in you have to stop guessing, the fact that the bike runs indicates everything he outlined for you to check is in fact somewhat working. But you are not going about this in a step by step mannor which means you'll throw needless time and money at this problem without a fix. Online everyone is a master mechanic and says "X fixed my problem, do that" but 99% of the time it's not YOUR problem and you've wasted whatever time and money it took to go there if you blindly follow. Krannie's trying to stop you from going down that route.
Explain again the above statement but in more detail. Do you mean the bike works exactly as it should on reserve, no choke needed to stay running? Then you have a fuel/petcock issue; remove the fuel tank, drain gas and check operation of petcock. Or even check fuel level to be sure you have enough gas. But if it simply doesn't run in the ON position, and will run on RES, though it has your symptoms described originally, you've more digging to do.
So it sounds like you rode the bike to a power wash station and cleaned it, were you cleaning off mud, salt, junk or just cleaning it in general? Have you done this before? A power washer can be a great tool to wash your bike, but in the wrong hands can be a missile launcher of water into places it shouldn't be. You must stay away from any bearings, vent hoses, exhaust opening and lightly go over electrical connections. If you force water into places it shouldn't be, well, its obvious what happens.
My thought before you get back to us with the above answers is water got somewhere it shouldn't, either in the carb directly or through the vent on the gas cap. Or water is making you have a bad electrical connection. Good thing is both areas are easy to fix on this bike by simply dumping the old gas (checking the petcock) and getting new, cleaning the carb and pulling all exposed electrical connections apart and making sure no water comes out. But first answer above, we can help pinpoint.
Edited by miweber929, 11 March 2013 - 04:58 AM.
Posted 12 March 2013 - 07:45 PM
Posted 12 March 2013 - 07:59 PM
Posted 13 March 2013 - 03:24 AM
13+, on 12 March 2013 - 07:59 PM, said:
I have done this befor, actually on a regular basies and I wash it the same way every time plus I stay two feet away from the bike with the nozzle just for this reason, i was washing mud and salt off casue i had some fun the day befor and this is the first its done this. It will run in the on position but only for ten seconds or so, and in reserve it find just fine while idleing but once I hit the throttle it dies but when I run the choke it doesn't spit or sputter but if I hit the throttle it dies, so since I did everything found one problem I'm sure I sucked something in to a jet and not the idle jet or air jet but I could be wrong about the air jet.
The thing that is confusing me on this is the petcock position: it should have no bearing on how an engine runs as its simply a delivery method for fuel which either comes down a tube a couple inches long (ON) or though the bottom of the petcock (res).
The fact that it runs better on choke indicates a fuel blockage so I'd lean towards fuel/carb. Did you soak the air filter with water? I'd start there and work my way downstream: filter, carb boot, carb clean, then drain the gas and start fresh as I think you may have gotten water in the fuel as well. Is your gas cap vent functional and in place?
Let us know how this progresses.
Posted 13 March 2013 - 04:28 AM
Difference yoy're experiencing between on and reserve at the petcock will probably come down to the fact that your fuel level is right at the point you would normally switch to reserve so add some fuel to the tank.
Posted 16 March 2013 - 04:58 PM
You asked for help, you received help, now it's time for you to reply and let us know what you found. Reason being if others have the same symptoms as you they can refer to this thread and hopefully get their issues sorted based on your results without a lot of drama.
If it was something simple all the better.
Again, my money is on the gas cap vent tube being plugged and your bike being close to reserve.
Let us know!
Posted 17 April 2013 - 07:20 PM
Posted 17 April 2013 - 07:24 PM
Posted 18 April 2013 - 11:59 AM
13+, on 17 April 2013 - 07:20 PM, said:
Did you change the pilot jet?
Posted 21 April 2013 - 11:00 AM
Any suggestions on a good after market needle?
Thanks again guy:)
View Garage
Follow us:
