Shopping for enclosed trailer
5 replies to this topic
  • paulsreef
Posted 10 March 2013 - 01:41 PM
I need an enclosed trailer for 4 motocross bikes and gear. What would be the minimum size? Being able to load and unload the bikes without losing my mind is important too. I'll be pulling it with a Dodge Ram 4x4 hemi. Thanks.
  • Chickenhauler
Posted 10 March 2013 - 01:47 PM
Depends on how tight you're willing to pack them.  I had a 5x10 + V-nose (13'6" from inside of rear door to interior of V-nose) and loaded the bikes diagonally, and could get 4 bikes in there.  It was tight, but it worked.
Don't have pics with 4 full size bikes in there, but here is one with one full size, a TTR and a XR80.  You can see there's room for another bike.
  • ktm450ds
Posted 10 March 2013 - 02:03 PM
I would get at least a 7X14 that gives you enough room to get 4 bikes in and still have a little wiggle room to tie down the bikes, and put gear. I would put shelves up like the mettle grated ones they sell that are light weight, but don't put to much weight on them they are good for helmets, boots, and hanging gear off of. With that size trailer you will still have some room to put heavy gear bags on the floor. Also a small cabinet up front is nice for oils, lube and stuff you don't want to spill.
  • toyota_mdt_tech
Posted 10 March 2013 - 06:00 PM
Depending on how you stack them, but for 2 deep, you figure about 8 feet for each row of bikes. So if you can get 3 wide (7-8 feet wide) then you will need to be another 8 feet deep. So a 7X16 or 8X16. That will get you plenty of room for gear.
  • paulsreef
Posted 10 March 2013 - 06:41 PM
Thanks, I figure I'll be safe with 7x16, and if I get a V-nose I could put some gear up front.
  • toyota_mdt_tech
Posted 10 March 2013 - 08:14 PM
I had an 8X14 (have a 7X16 now)  and I cant tell you how much I'd like to have had the extra space. Its a must and if you ever need to haul a pair of utility quads also (back to back, they wont fit side by side) .With the 16 footer,  I'm never crowed tucking in bikes. I always say. "multiples of 8 feet if you hauling bikes and/or quads".  I went 7 feet wide, because it was just easier to see down the sides with my truck mirrors and also, it tucks it behind the truck a little tighter for less wind drag/economy.
Edited by toyota_mdt_tech, 17 March 2013 - 08:03 AM.
